I compare it to the GHI 3.5" Fez tft exp shield coming with cobra board and it seems to me that they are quite similar (same resolution, Parallel RGB +Hsync, Vsync, enable and clock)… What I did not understand is that in both case the datasheet mentions “recommand initial code” that should be sent via SPI … What is strange is that on the GHI 3.5" shield the SPI signals are just connected to test points and there is no serial connection between the screen and the board… just parallel RGB+Hsync, Vsync, enable and clock…
So I wonder what do I miss? Is that serla sequence optional? if yes, do we need to check? (I am currently trying to scope enable and reset signals…)
Any clues or things to check?
