We have a piezo buffer on our board. The following code works fine:
TempComponents.PWMPiezoController = PwmController.FromName(SC20260.PwmChannel.Controller5.Id);
TempComponents.PWMPiezo = TempComponents.PWMPiezoController.OpenChannel(SC20260.PwmChannel.Controller5.PI0);
TempComponents.PWMPiezoController.SetDesiredFrequency(1000.0);
TempComponents.PWMPiezo.SetActiveDutyCyclePercentage(0.56);
TempComponents.PWMPiezo.Start();
The :LCD backlight is on SC20260 pin 130 (PI7). If I use this pin as straight GPIO then it works as expected. This pin can also be setup as PWM. The following code does not work:
TempComponents.PWMcontroller = PwmController.FromName(SC20260.PwmChannel.Controller8.Id);
TempComponents.PWMcontroller.SetDesiredFrequency(1000.0);
DataDefs.BacklightPwmLED = TempComponents.PWMcontroller.OpenChannel(SC20260.PwmChannel.Controller8.PI7);
DataDefs.BacklightPwmLED.SetActiveDutyCyclePercentage(1.0);
DataDefs.BacklightPwmLED.Start();
In fact, when the Start() is called the entire system fails. (strange behavior everywhere)
Pin 130 is defined as
PI7 or PWM8.3
Is the pwm set up correct ?
