I currently use the LargeBuffer as part of an spi transfer process. The size of the LargeBuffer can be changed from a database setting. I was wondering if I change the size to say 100KB, is there an issue in still using Largebuffer? I know the documentation states it is usually used when you need buffers larger than 700KB.
Even in general, is there a performance hit in declaring and using LargeBuffers?
