In my tests i use custom driver
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
using Gadgeteer;
namespace Spider_v0
public class MotorControllerL298_2 : GTM.Module
GTI.PWMOutput m_Pwm1;
GTI.PWMOutput m_Pwm2;
OutputPort m_Direction1;
OutputPort m_Direction2;
int m_lastSpeed1 = 0;
int m_lastSpeed2 = 0;
// This example implements a driver in managed code for a simple Gadgeteer module. The module uses a
// single GTI.InterruptInput to interact with a sensor that can be in either of two states: low or high.
// The example code shows the recommended code pattern for exposing the property (IsHigh).
// The example also uses the recommended code pattern for exposing two events: MotorControllerL298High, MotorControllerL298Low.
// The triple-slash "///" comments shown will be used in the build process to create an XML file named
// GTM.GHIElectronics.MotorControllerL298. This file will provide Intellisense and documention for the
// interface and make it easier for developers to use the MotorControllerL298 module.
// Note: A constructor summary is auto-generated by the doc builder.
/// <summary></summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public MotorControllerL298_2(int socketNumber)
// This finds the Socket instance from the user-specified socket number.
// This will generate user-friendly error messages if the socket is invalid.
// If there is more than one socket on this module, then instead of "null" for the last parameter,
// put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported(new char[] { 'P' }, this);
// Set up the PWM pins
m_Pwm1 = new GTI.PWMOutput(socket, Socket.Pin.Seven, false, this);
m_Pwm2 = new GTI.PWMOutput(socket, Socket.Pin.Eight, false, this);
m_Direction1 = new OutputPort(socket.CpuPins[9], false);
m_Direction2 = new OutputPort(socket.CpuPins[6], false);
m_Pwm1.Set(1000, 0);
m_Pwm2.Set(1000, 0);
// This creates an GTI.InterruptInput interface. The interfaces under the GTI namespace provide easy ways to build common modules.
// This also generates user-friendly error messages automatically, e.g. if the user chooses a socket incompatible with an interrupt input.
this.input = new GTI.InterruptInput(socket, GT.Socket.Pin.Three, GTI.GlitchFilterMode.On, GTI.ResistorMode.PullUp, GTI.InterruptMode.RisingAndFallingEdge, this);
// This registers a handler for the interrupt event of the interrupt input (which is below)
this.input.Interrupt += new GTI.InterruptInput.InterruptEventHandler(this._input_Interrupt);
private void _input_Interrupt(GTI.InterruptInput input, bool value)
this.OnMotorControllerL298Event(this, value ? MotorControllerL298State.Low : MotorControllerL298State.High);
private GTI.InterruptInput input;
/// <summary>
/// Gets a value that indicates whether the state of this MotorControllerL298 is high.
/// </summary>
public bool IsHigh
get
return this.input.Read();
/// <summary>
/// Represents the state of the <see cref="MotorControllerL298_2"/> object.
/// </summary>
public enum MotorControllerL298State
/// <summary>
/// The state of MotorControllerL298 is low.
/// </summary>
Low = 0,
/// <summary>
/// The state of MotorControllerL298 is high.
/// </summary>
High = 1
/// <summary>
/// Represents the desired motor to use.
/// </summary>
public enum Motor
/// <summary>
/// The left motor, marked M1, is the one in use.
/// </summary>
Motor1 = 1,
/// <summary>
/// The right motor, marked M2, is the one in use.
/// </summary>
Motor2 = 2,
/// <summary>
/// Used to set a motor's speed.
/// <param name="_motorSide">The motor <see cref="Motor"/> you are setting the speed for.</param>
/// <param name="_newSpeed"> The new speed that you want to set the current motor to.</param>
/// </summary>
public void MoveMotor(Motor _motorSide, int _newSpeed)
#if DEBUG
Debug.Print( "Motor: " + _motorSide + ", Speed: " + _newSpeed );
#endif
// Make sure the speed is within an acceptable range.
if (_newSpeed > 100 || _newSpeed < -100)
new ArgumentException("New motor speed outside the acceptable range (-100-100)", "_newSpeed");
// Motor1
if (_motorSide == Motor.Motor1)
if ( m_lastSpeed1 == _newSpeed )
return;
// Save our speed
m_lastSpeed1 = _newSpeed;
// Determine the direction we are going to go.
if (_newSpeed < 0)
// Set direction and power.
m_Direction1.Write(true);
m_Pwm1.Set(1000, (double)((100 - System.Math.Abs(_newSpeed)) / 100.0));
if ( _newSpeed == 0 )
_newSpeed = 1;
m_Direction1.Write(false);
m_Pwm1.Set(1000, (double)(_newSpeed / 100.0));
// Motor2
if ( m_lastSpeed2 == _newSpeed )
return;
// Save our speed
m_lastSpeed2 = _newSpeed;
if (_newSpeed < 0)
m_Direction2.Write(true);
m_Pwm2.Set(1000, (double)((100 - System.Math.Abs(_newSpeed)) / 100.0));
_newSpeed = 1;
m_Direction2.Write(false);
m_Pwm2.Set(1000, (double)(_newSpeed / 100.0));
/// <summary>
/// Used to set a motor's speed with a ramping acceleration. <see cref="MoveMotor"/>
/// <param name="_rampingDelayMilli"> The time in which you want the motor to reach the new speed (in milliseconds).</param>
/// </summary>
public void MoveMotorRamp(Motor _motorSide, int _newSpeed, int _rampingDelayMilli)
int temp_speed;
int startSpeed;
int lastSpeed;
int timeStep;
int deltaTime = 0;
// Determine which motor we are going to change.
temp_speed = m_lastSpeed1;
startSpeed = m_lastSpeed1;
lastSpeed = m_lastSpeed1;
temp_speed = m_lastSpeed2;
startSpeed = m_lastSpeed2;
lastSpeed = m_lastSpeed2;
if ( _newSpeed == lastSpeed )
return;
// Determine how long we need to wait between move calls.
timeStep = _rampingDelayMilli / (_newSpeed - lastSpeed);
// Ramp
while (_newSpeed != temp_speed)
// If we have been updating for the passed in length of time, exit the loop.
if (deltaTime >= _rampingDelayMilli)
break;
// If we are slowing the motor down.
if (temp_speed > _newSpeed)
temp_speed += ((startSpeed - _newSpeed) / timeStep);
// If we are speeding the motor up.
if (temp_speed < _newSpeed)
temp_speed -= ((startSpeed - _newSpeed) / timeStep);
// Set our motor speed to our new values.
MoveMotor(_motorSide, temp_speed);
// Increase our timer.
deltaTime += System.Math.Abs(timeStep);
// Wait until we can move again.
Thread.Sleep(System.Math.Abs(timeStep));
/// <summary>
/// Represents the delegate that is used to handle the <see cref="MotorControllerL298High"/>
/// and <see cref="MotorControllerL298Low"/> events.
/// </summary>
/// <param name="sender">The <see cref="MotorControllerL298_2"/> object that raised the event.</param>
/// <param name="state">The state of the MotorControllerL298</param>
public delegate void MotorControllerL298EventHandler(MotorControllerL298_2 sender, MotorControllerL298State state);
/// <summary>
/// Raised when the state of <see cref="MotorControllerL298_2"/> is high.
/// </summary>
/// <remarks>
/// Implement this event handler and the <see cref="MotorControllerL298Low"/> event handler
/// when you want to provide an action associated with MotorControllerL298 activity.
/// The state of the MotorControllerL298 is passed to the <see cref="MotorControllerL298EventHandler"/> delegate,
/// so you can use the same event handler for both MotorControllerL298 states.
/// </remarks>
public event MotorControllerL298EventHandler MotorControllerL298High;
/// <summary>
/// Raised when the state of <see cref="MotorControllerL298_2"/> is low.
/// </summary>
/// <remarks>
/// Implement this event handler and the <see cref="MotorControllerL298High"/> event handler
/// Since the state of the MotorControllerL298 is passed to the <see cref="MotorControllerL298EventHandler"/> delegate,
/// you can use the same event handler for both MotorControllerL298 states.
/// </remarks>
public event MotorControllerL298EventHandler MotorControllerL298Low;
private MotorControllerL298EventHandler onMotorControllerL298;
/// <summary>
/// Raises the <see cref="MotorControllerL298High"/> or <see cref="MotorControllerL298Low"/> event.
/// </summary>
/// <param name="sender">The <see cref="MotorControllerL298_2"/> that raised the event.</param>
/// <param name="MotorControllerL298State">The state of the MotorControllerL298.</param>
protected virtual void OnMotorControllerL298Event(MotorControllerL298_2 sender, MotorControllerL298State MotorControllerL298State)
if (this.onMotorControllerL298 == null)
this.onMotorControllerL298 = new MotorControllerL298EventHandler(this.OnMotorControllerL298Event);
if (Program.CheckAndInvoke((MotorControllerL298State == MotorControllerL298State.High ? this.MotorControllerL298High : this.MotorControllerL298Low), this.onMotorControllerL298, sender, MotorControllerL298State))
switch (MotorControllerL298State)
case MotorControllerL298State.High:
this.MotorControllerL298High(sender, MotorControllerL298State);
break;
case MotorControllerL298State.Low:
this.MotorControllerL298Low(sender, MotorControllerL298State);
break;
