I donāt have that module, but typically with devices like this, there are 2 values specified.
One is for the power needed to run the chip (up to 5v in this case comes through the gadgeteer cable),and the other is the power being sent to the motors (up to 40v 3a).
If you are using the same power source for both the GHI and motors, then you need to be sure it can supply enough voltage and amps to run both. When the motor starts spinning it will usually quickly pull alot of power, and it you are using 1 source, this may cause your main board to restart when this happens.
Thank all of you guys!!! This was the matter, i set the 6v wall wart as a power suply and get it done!!! Battery are woefully poor power sources!
Can you advice any good power sources for the future when i would like to power up the robot not from the wall charger?
Big C or D size batteries, or lipo batteries as used in remote control cars. Either of those have a much greater capacity and ability to deliver as a current source.
Now we need to see videos of your device in action.
In the past Iāve used a battery pack from a cordless screwdriver. If you take it apart there are a collection of cells that look to be about the size of C cells (they are a bit different though).
The tricky part is recharging them - so be sure to think that part through before ripping the wires between the cells apart (like I did :). Also, with the packs I had, I couldnāt solder wires to the cells, I guess it had to do with the metals used - or that I had a cheap iron at the time.
I wrote it down guysā¦ thank you one more time. I will definetly upload some videos, but later on when i teach the robo to do something. Firstly i am going to find out how to control motors from button events in windows app with usb cable connected to mainboard. Because now i found out only how to load a project to mainboard and run it. Sample of code would be greatā¦
Now i load this code to mainboard directly from IDE (VS 2012):
I did something sort of like this using the Xbee-compatible RN171 module, like this one http://www.sparkfun.com/products/10822. I used it to control a cpu fan, a display, sensor and LEDS from different button presses on a phone.
Yes, mhectorgato right. I meant to use a buttons in windows app. just as in regular visual studio c# project, put 4 buttons on the windows app form and handle button click events directly on Cerbuino bee mainboard.
I already have a usb host on Cerbuino bee, can i use this one? Or is it possible to handle windows buttons events through a USB client on mainboard that is used to load the gadgeteer project to device?
I already have a RN-XV WiFly Module (Xbee),L2 gadgeteer camera and HD44780 display module from Pete Brown video (Controlling a NETMF Gadgeteer Robot from a Windows 8 App - Pete Brown's 10rem.net). Finally i want to control my robot from android smartphone via wifi and stream the video from L2 camera to smartphone, but before i start a hardcoding and all stuff with TCP sockets and wifi it would be fine to test a simple movments: forward,backward,stop,left,right on simple windows app with 4 buttonsā¦
