Support for float and double has been added in pull request 475
There’s also a fix for processing of DateTime serialization and deserialization which was causing exceptions under some conditions.
This is the test code that I used:
using System.Diagnostics;
using GHIElectronics.TinyCLR.Data.Json;
namespace TinyCLRApplication3
public class ChildClass
public int one;
public int two;
public int three;
public class TestClass
public int i;
public float f;
public double d;
public string aString;
public string someName;
public DateTime Timestamp;
public int[] intArray;
public string[] stringArray;
public ChildClass child1;
public ChildClass Child { get; set; }
class Program
static void Main()
DoArrayTest();
DoDoubleTest();
DoSimpleObjectTest();
DoComplexObjectTest();
private static void DoArrayTest()
int[] intArray = new[] { 1, 3, 5, 7, 9 };
var result = JsonConverter.Serialize(intArray);
var bson = result.ToBson();
var compare = JsonConverter.FromBson(bson, typeof(int[]));
if (!ArraysAreEqual(intArray, (Array)compare))
throw new Exception("array test failed");
Debug.WriteLine("Array test succeeded");
private static void DoDoubleTest()
double[] dArray = new[] { 1, 3, 5, double.NaN, 9 };
var result = JsonConverter.Serialize(dArray);
var compare = JsonConverter.FromBson(bson, typeof(double[]));
if (!ArraysAreEqual(dArray, (Array)compare))
private static void DoSimpleObjectTest()
var source = new ChildClass()
one = 1,
two = 2,
three = 3
var serialized = JsonConverter.Serialize(source);
var bson = serialized.ToBson();
var compare = (ChildClass)JsonConverter.FromBson(bson, typeof(ChildClass));
if (source.one != compare.one ||
source.two != compare.two ||
source.three != compare.three)
throw new Exception("simple object test failed");
Debug.WriteLine("simple object test passed");
private static void DoComplexObjectTest()
var test = new TestClass()
aString = "A string",
i = 10,
f = 3.1415925f,
d = 2 * 3.1415925,
someName = "who?",
Timestamp = DateTime.UtcNow,
intArray = new[] { 1, 3, 5, 7, 9 },
stringArray = new[] { "two", "four", "six", "eight" },
child1 = new ChildClass() { one = 1, two = 2, three = 3 },
Child = new ChildClass() { one = 100, two = 200, three = 300 }
var result = JsonConverter.Serialize(test);
Debug.WriteLine("Serialization:");
var stringValue = result.ToString();
Debug.WriteLine(stringValue);
var dserResult = JsonConverter.Deserialize(stringValue);
Debug.WriteLine("After deserialization:");
Debug.WriteLine(dserResult.ToString());
var newInstance = (TestClass)JsonConverter.DeserializeObject(stringValue, typeof(TestClass), CreateInstance);
if (test.i != newInstance.i ||
test.f != newInstance.f ||
test.d != newInstance.d ||
test.Timestamp.ToString() != newInstance.Timestamp.ToString() ||
test.aString != newInstance.aString ||
test.someName != newInstance.someName ||
!ArraysAreEqual(test.intArray, newInstance.intArray) ||
!ArraysAreEqual(test.stringArray, newInstance.stringArray)
throw new Exception("complex object test failed");
// bson tests
var compare = JsonConverter.FromBson(bson, typeof(TestClass), CreateInstance);
private static object CreateInstance(string path, string name, int length)
if (name == "intArray")
return new int[length];
else if (name == "stringArray")
return new string[length];
return null;
private static bool ArraysAreEqual(Array a1, Array a2)
if (a1 == null && a2 == null)
return true;
if (a1 == null || a2 == null)
return false;
if (a1.Length != a2.Length)
return false;
for (int i = 0; i < a1.Length; ++i)
if (!a1.GetValue(i).Equals(a2.GetValue(i)))
return false;
return true;
thanks for everything
