Json Deserialized example
I have a fairly complex json string that I can successfully parse under preview 3 but when I move the code to preview 4 I’m getting an unhandled null reference exception. I have narrowed the issue down to creating the instance with a custom array object ( daily[] ) in the root of the object, the name and length properties are null, and -1 no matter what I try. If I use a native type (string[]) it initialized as expected.
I have created a ready to run test project that includes working code for preview firmware 3 and the same example with firmware 4 that fails. Any advice anyone might have to get this code working under preview 4 would be greatly appreciated.
JsonTest.zip
static void Main()
    string validJson = "[see test project for full string and custom objects]";
    Debug.WriteLine(validJson);  // This is valid JSON.  Checked on a couple differnt websites.
    var jsonResponse =  (WeatherResponse)JsonConverter.DeserializeObject(validJson, typeof(WeatherResponse), CreateInstance);
    Debug.WriteLine($"Temp: {jsonResponse.current.temp}");
private static object CreateInstance(string path, JToken root, Type baseType, string name, int length)
    if (path == "/" & name == "daily")
        return new Daily[length];
    else if (path == "//daily" & name == null)
        return new Daily();
    else if (path == "//daily" & name == "weather")
        return new Weather[length];
    else if (path == "//daily/weather" & name == null)
        return new Weather();
    else if (path == "/current" & name == "weather")
    else if (path == "/current/weather" & name == null)
    else
        return null;
