Would be great if it worked right. The x pot is not centered and requires like a 30deg left stick before registering change and then the change is really big. Going straight upstick, also changes X full left which is weird, so must be gnd’ing some how. Anyone used more high quality breakout joy sticks? I could think it was just a defective pot, but other comments suggest it is a quality issue that would not be overcome by just a replacement of the same thing. As it is, I can’t overcome these issues with software. TIA.
For jumpering traces 30AWG wire wrap wire is your friend. Use your soldering iron to strip it, i.e. melt the insulation off the ends, as it is very hard to strip. Tack it to one trace route it to the other trace, holding it in place with a drop of super glue, then solder to the second trace.
