So I am starting to understand how this works thanks to the samples in the Code section
I can put a cursor on the screen and have the joystick move it around but it leaves a trail on the screen and while it looks all cool and tripy it is not what i want
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace JoystickTest
public partial class Program
private uint displayWidth;
private uint displayHeight;
private int cursorXPos;
private int cursorYPos;
private Bitmap cursor;
private int lastYpos;
private int lastXpos;
displayWidth = display.Width - 7;
displayHeight = display.Height - 7;
DrawHomeScreen();
cursorXPos = (int)displayWidth / 2;
cursorYPos = (int)displayHeight / 2;
lastXpos = -1;
lastYpos = -1;
Timer timedEvent = new Timer(updateJoystick, null, 0, 10);
cursor = new Bitmap(15, 15);
private void updateJoystick(Object o)
// A Timer calls this method every 50ms
int x = (int)((joystick.GetJoystickPostion().X * 2.0 - 1.0) * 5);
int y = (int)((joystick.GetJoystickPostion().Y * 2.0 - 1.0) * -5);
cursorXPos += x;
cursorYPos += y;
if (cursorXPos < 0) cursorXPos = 0;
if (cursorXPos >= displayWidth) cursorXPos = (int)displayWidth - 1;
if (cursorYPos < 0) cursorYPos = 0;
if (cursorYPos >= displayHeight) cursorYPos = (int)displayHeight - 1;
DrawCursor();
private void DrawCursor()
if (lastXpos == cursorXPos && lastYpos == cursorYPos)
return;
// display.SimpleGraphics.DisplayImage(homeScreen, 0, 0);
display.SimpleGraphics.DisplayImage(cursor, (uint)cursorXPos, (uint)cursorYPos);
lastXpos = cursorXPos;
lastYpos = cursorYPos;
private void DrawHomeScreen()
display.SimpleGraphics.BackgroundColor = GT.Color.Blue;
do I need to set a timer to redraw the screen and only show the cursor?
