The mounting holes on mine and possibly all boards are not spaced on a 5mm grid across the width. Anyone else run into this problem? if so, how did you mount it?
All GHI modules are spaced on a 5mm grid. That board is not set up to that standard.
From the dimensions PDF on the Resources Tabb for this module it states:
SCREW HOLE DIAMETERS ARE 3.2MM, COMPLIANT WITH THE GADETEER STANDARD. HOLE SPACING IS BASED ON A 5MM GRID ALL DIMENSIONS ARE ± 0.5MM.
I guess this is misleading.
Thanks for clearing this up.
this needs to be clarified on the website. Thanks for pointing this out.
Exact dimension will be posted.
The files found under the Catalog Resources tab have been updated. Thanks for pointing out the problem.
