While the FEZ can easily do all of your required functions, there is a limitation on the number of interrupts per second that can be handled. You would count pulses with an interrupt.
I have been doing some studies on this subject and have found that if the interrupt rate is too fast, memory will be gobbled up until the system runs out of memory.
On a Domino, a sustained rate of around 3500 interrupts per second will crash the system within a few seconds.
I have not looked at the Cobra, where there is lots of memory.
counter 1 would have max 1 interrupt every 10 secs
counter 2 would have max 3 interrupts every second
counter 3 would have max 5 interrupts every second
i guess that won’t be a problem?
What will happen if pulses on 2 counters come in at the exact same time ? Will they both be seen ?
The rates you specified seem very reasonable, depending upon how much processing you need to do on each interrupt.
I would suggest putting the interrupt data into a queue and processing the data with a seperate thread. You want to minimize the time in the interrupt handler.
Multiple interrupts at the same time should be handled fine.
There is a delay between the time that a signal changes and when it appears at the interrupt handler. The interrupt contains an accurate timestamp, which represent when the signal changed. The delay is in milliseconds.
FEX is not a real-time system. I don’t think this is an issue if you are just counting pulses.
I’m still not sure if I’ll go for a Cobra board to handle everything, or split up tasks over multiple connected Domino’s or Panda’s.
Besides the interrupt counters, I also want to have events send over Ethernet when for example the thermostat switches on/off, when the heating turns on/off, when the garage door opens/closes. I’m also looking at integrating RF433/868 communications to have also events/statuses of open doors/windows and switch outlets either on command or based on events and or time. Motion detection will also be part of the setup.
What I’m trying to build is some sort of home controller (domotica).
Any suggestions are highly appreciated.
PS. Is there a driver for the HopeRF RFM12B module?
Ohw domotica, that sounds great! if I got my panda’s I’m going to try to build something like that too, maybe not so complex, but a more simple version. Great!
This is probably a stupid question but what triggers the interrupt? Is it a threshold value set on your sensors, or is the frequency of the sensor output?
If the aim of the project is to track how the values for electricity / gas / water changes over time, wouldn’t it be better to read the values in a loop with individual timing threads if need be?
As I dont know how your sensors are interfaced, analogue line, I2C, UART
I can only give you a rough example. The only thing I have resembling a sensor is a I2C compass. Not all that useful for you if your house isnt on the move…
namespace psudo
SensorElec Elec = new SensorElec();
SensorGas Gas = new SensorGas();
SensorWater Water = new SensorWater();
I2C_Compass Compass = new I2C_Compass();
double CurrentElec = Elec.Value;
double CurrentGas = Gas.Value;
double CurrentWater = Water.Value;
string Heading = Compass.ReadHeading.ToString("F0");
//do something else...
Thread.Sleep(1000);
public class I2C_Compass : IDisposable
const ushort HMC6352_ADDRESS = 0x21;
const int CLOCK_FREQ = 100;
const int DELAY = 50;
//Write Buffer
byte[] A = new byte[] { 0x41 }; // A command
//Read Buffer
byte[] inBuffer = new byte[2];
//Init I2C Device Config
I2CDevice.Configuration config = new I2CDevice.Configuration(HMC6352_ADDRESS, CLOCK_FREQ);
//Init I2C Device & Read/Write Transactions
I2CDevice cmp;
I2CDevice.I2CWriteTransaction writeTrans;
I2CDevice.I2CReadTransaction readTrans;
public I2C_Compass()
cmp = new I2CDevice(config);
writeTrans = I2CDevice.CreateWriteTransaction(A);
readTrans = I2CDevice.CreateReadTransaction(inBuffer);
public void Dispose()
cmp.Dispose();
config = null;
writeTrans = null;
readTrans = null;
public double ReadHeading
get
//Execute Both Transactions and Return Heading as float with 0.1 deg resolution
I2CDevice.I2CTransaction[] transactions = new I2CDevice.I2CTransaction[] { writeTrans, readTrans };
cmp.Execute(transactions, DELAY);
int heading = inBuffer[0] * 256 + inBuffer[1];
double realHeading = (double)(heading / 10.0f);
return realHeading;
you shouldn’t need to pass all your details to the pc to do process, there’s no reason you can’t do it on the fez and then just put the calculated results over to the PC.
I’m doing some very complex maths and able to read an analogue pin, process the value with some complex maths then run filtering, averaging, and selection on the samples over 2500 times a second.
