Just want to double check that it is safe for one thread to write to one file on a microSD card while another thread reads from a different file on the same card.
I’ve been pretty successful at writing my current app so nothing blocks except for when I have to transfer a file using Iridium satellites. My code uses XModem for .Net Micro from Iggmoe and it would be pretty hard to make that non-blocking. So my current code blocks and my state machine stalls while I transfer the file. It makes sense to me to move the file transfer to another thread so my state machine can continue monitoring the system but I just want to make sure the two threads won’t be stomping on each other trying to access the file system. Also, I have to figure out how to pass the parameters the file transfer thread needs to access the SD card.
Thanks for the help.
