When a class is assigned to an object and you want to cast the object value to an inherited interface of the original class, an InvalidCastException is raised. For the life of me, I cannot figure out why. I am new to NetMF code, so I am assuming that I am doing something very wrong.
This works in the normal .Net code.
Option Explicit On
Option Strict On
Imports Microsoft.SPOT
Namespace InterfaceTest
Public Module Module1
Sub Main()
Dim obj As Object
Dim test As IBase
Dim level1 As ILevel1
Dim local As New Level1
' Exercise the instances.
local.BaseTest()
level1 = local
level1.BaseTest()
test = level1
test.BaseTest()
' Assign to object.
obj = local
' Cast to direct interface. This works.
Dim test2 As ILevel1 = CType(obj, ILevel1)
test2.BaseTest()
' Cast to base interface. This throws InvalidCastException.
Dim test3 As IBase = CType(obj, IBase)
test3.BaseTest()
End Sub
End Module
Public Interface IBase
Sub BaseTest()
End Interface
Public Interface ILevel1
Inherits IBase
End Interface
Public Class Level1
Implements ILevel1
Public Sub BaseTest() Implements IBase.BaseTest
Debug.Print("Base Test")
End Sub
Public Sub LocalTest()
Debug.Print("Local Test")
End Sub
End Class
End Namespace
