Hi all,
Can someone tell me why i do get an exception when attaching an oninterrupt method to interruptport 29 on my EMX dev.board.
Thanks in advance.
CODE:
var sensorInterrupt = new InterruptPort(EMX.Pin.IO29, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
sensorInterrupt.OnInterrupt += sensorInterrupt_OnInterrupt;
Exception System.ArgumentException - 0xfd000000 (1)
Message:
Microsoft.SPOT.Hardware.InterruptPort::EnableInterrupt [IP: 0000]
Microsoft.SPOT.Hardware.NativeEventDispatcher::add_OnInterrupt [IP: 0027]
Try casting the first argument to a Cpu.Pin
The exception is raised after:
The exception is NOT raised if i take another pin for example: EMX.PIN.IO0
I have the idea that the interrupt is internally reserved for COM3, but not sure
Mike
4
According to the EMX Brochure and Pinout document, pin IO29 is NOT interrupt capable.
