Hi all, i have a slight problem, i am trying to run some motors via my fez panda2. I have 2 limit switches connected to the ends of the tracks of the motors and i am using the motor in PWM mode.
I have setup 2 interrupt routines for the limit switches and some debug LED’s so that i know if the routine run or not. The routine is simply meant to change the direction of the motor direction via a single digital i/o. The uart is used to send simple commands to start/stop or change the direction of the motor.
The code runs properly if the motors are not in operation, and the debug LED’s only change state when i manually touch the limit switches. But as soon as i start up the motors via PWM the interrupts are triggering randomly. I know the interrupts are triggering as i can see that from the debug LED’s.
I have probed the i/o pins of the interrupts and those pins are not changing state - so the interrupts are just randomly triggering. i am also using a schmitt trigger circuit before the interrupt pins to ensure that there is no grey are that may trigger an interrupt.
I have attempted to remove the PWM mode and run the h-bridges of a digital i/o line but this did not change anything.
please advise.
Thanks in advance
// code for the linear
using Microsoft.SPOT.IO;
using System.IO;
using System.Text;
using System.IO.Ports;
namespace MFConsoleApplication8
static OutputPort LED;
static OutputPort Debug1;
static OutputPort Debug2;
static OutputPort Debug3;
static OutputPort MotorDirection;
static PWM PWMMotor;
static InterruptPort LimitSwitchA;
static InterruptPort LimitSwitchB;
// Use UART channel 1
static SerialPort UART = new SerialPort("COM1", 115200);
LED = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, false);
Debug1 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di50, false);
Debug2 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di51, false);
Debug3 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di52, false);
MotorDirection = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di38, false);
PWMMotor = new PWM((PWM.Pin)FEZ_Pin.PWM.Di5);
//uart open
UART.Open();
UART.DataReceived += new SerialDataReceivedEventHandler(UART_DataReceived);
TimeSpan ts = new TimeSpan(0, 0, 0, 0, 500);
Microsoft.SPOT.Hardware.Cpu.GlitchFilterTime = ts;
LimitSwitchA = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.Di37, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeHigh);
LimitSwitchB = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.Di39, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
LimitSwitchA.OnInterrupt +=new NativeEventHandler(LimitSwitchA_OnInterrupt);
LimitSwitchB.OnInterrupt += new NativeEventHandler(LimitSwitchB_OnInterrupt);
Debug1.Write(true);
Debug.Print(">>> setup complete <<<");
LED.Write(!LED.Read());
Thread.Sleep(200);
}//end of class
static void LimitSwitchB_OnInterrupt(uint data1, uint data2, DateTime time)
{ // setting the pwm
PWMMotor.Set(200, 0);
Thread.Sleep(100);
Debug2.Write(!Debug2.Read());
MotorDirection.Write(!MotorDirection.Read());
Thread.Sleep(100);
// setting the pwm
PWMMotor.Set(200, 100);
static void LimitSwitchA_OnInterrupt(uint data1, uint data2, DateTime time)
// setting the pwm
Thread.Sleep(100);
Debug3.Write(!Debug3.Read());
Thread.Sleep(100);
// setting the pwm
static void UART_DataReceived(object sender, SerialDataReceivedEventArgs e)
Debug2.Write(true);
byte[] rx_data = new byte[10];
UART.Read(rx_data, 0, 1);
if (rx_data[0] != 10)
String UARTrx = ("UART MESSAGE RECIEVED, data:" + rx_data[0] + "\r\n");
byte[] UARTrxBuffer = Encoding.UTF8.GetBytes(UARTrx);
UART.Write(UARTrxBuffer, 0, UARTrxBuffer.Length);
//97 = char a
if (rx_data[0] == 97)
String msg1 = ("going to START pwm motor" + "\r\n");
byte[] msg1Buffer = Encoding.UTF8.GetBytes(msg1);
UART.Write(msg1Buffer, 0, msg1Buffer.Length);
// setting the pwm
PWMLED.Set(200, 100);
Debug.Print(">>> PWM set <<<");
}//end if rx data
//98 = char b
else if (rx_data[0] == 98)
String msg2 = ("going to STOP pwm motor" + "\r\n");
byte[] msg2Buffer = Encoding.UTF8.GetBytes(msg2);
UART.Write(msg2Buffer, 0, msg2Buffer.Length);
// setting the pwm
PWMLED.Set(200, 0);
}//end else if rx data
//98 = char c
else if (rx_data[0] == 99)
String msg2 = ("going to change motor direction" + "\r\n");
}//end if
}//end of rx data received event
}//end class
}//end name space
