However, I put in 2ms wide pulses every 800ms & the interrupt triggers every so often (using debug print to see it). The wave is clean from a generator.
Even a 10ms or 1ms pulse will occasionally trip it…what’s wrong? I also tried setting the filter to 20ms, same thing
Is this a priority thing? Can I change the priority? I’m not familiar with netmf interrupts
I’ am afraid I dont get what you mean: if you want to stretch the original pulse then you need a hardware device called a mono-stable multivibrator (not what you think it is ) , or a RC-filter (resistor and capacitor) on the input.
My alternative would be to use your own RLP interrupt-handler…and implement the filter-algoritm yourself.
