Another everything-killer. I wonder what a full system costs, with the interesting stuff broken out. Would be interesting to have NETMF ported to the bare metal.
The Sparkfun battery “block” is a only 400mah … wonder what type of runtime that would provide (understood that this is dependent on CPU load and amount of wireless communications)/
Disagree completely. It’s tiny, has 2 types of wireless built in and is reasonably priced.
Obviously will need to wait and see, but so far looks very capable.
From the marketing page:
•The Intel Edison module uses a 22-nm Intel® Atom™ SoC, formerly Silvermont that includes a dual core, dual threaded CPU at 500 MHz and a 32-bit Intel® Quark™ processor MCU at 100 MHz. It supports 40 GPIOs and includes: 1 GB LPDDR3, 4 GB EMMC, and dual-band WiFi and Bluetooth® Low Energy on a module the size of a postage stamp.
•The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
I would be VERY interested in seeing it benchmarked against the Pi. I’ve recently run into a hitch with a Pi, with something it just doesn’t seem to have the horsepower to handle (tvheadend). I’m having to consider other options.
Currently, I’m looking at a VIA L2007 board. It’s not fanless, so not ideal, but I can get the motherboard, CPU, and 2GB RAM for under $60.
@ mhectorgato - so far all I can find is 100ma 3v3 and 100ma 1v8
So if it is 200ma…not long…
Edit that might be what the module can supply from the spec and not possibly what it consumes. All they state for draw is 35mW in standby with WiFi and no active figures…
Think of it as a more powerful Raspberry Pi in a smaller form factor, and a little more expensive. It also, as others have said, has built-int wireless.
This is NOT a competitor to Cortex-M microcontrollers, it’s a whole other beast.
Kinda makes you wonder about G-400, though. This is cheaper (significantly cheaper in the case of the G400-D), MUCH more powerful, and has built-in WiFi and BT4.
Arduino in this context is a programming environment. It’s not a hardware spec or anything else, just like NETMF isn’t.
Hydra and USBizi are vastly different things, but nobody complained when they said “program with Visual Studio and NETMF”. No reason to complain when Intel says “program with Arduino”.
@ Justin - Quote from Intel:
"Edison is a low power device. In general it will not draw more than 200 mA (approximately 430 mA (final value TBD) when transmitting over Wi-Fi) from the main power source. "
200mA is double the G400-S spec. Based on processor speed and cores, plus the addition of the radios 200mA seems reasonable. Its probably not the best solution for a battery/solar powered IoT sensor. But as a gateway device or other line powered application it looks promising.
You won’t need to bother with NETMF on this. It will run Full .Net with windows embedded. For less than $50, this is a game changer. I just wonder if it has a watchdog and how long it would take to boot.
Do not wonder Our commercial customers are very happy with NETMF. Using a full operating system comes with benefits but has negatives as well. They will not use this nor use rpi. Also, price is not the main decider for them. They used to pay $160 each for chipworkx do now G400 is lower cost and at better performance.
