HI,
How can I use the Bitmap or Image class to store the image from Camera Module?
Did .NETMF or GHI have class to get the pixel from the image?
For my application, I need to get the R,G,B pixel and store to array for further processing.
Thanks.
Check this post.
http://www.tinyclr.com/forum/21/4703/#/2/msg45145
There is piece of code that converts bitmap into a BMP byte array. BMP is 54 bytes of header information and then raw rgb values.
Thanks;
Next step is how to get the position pixel.
How to do in NETMF like this
public int[,,] getRGBData()
Bitmap Bpimage = new Bitmap(image);
int Height = Bpimage.Height;
int Width = Bpimage.Width;
int[,,] rgbData=new int[Width,Height,3];
for(int y=0;y<Height;y++)
for(int x=0;x<Width;x++)
Color color=bimage.GetPixel(x,y);
rgbData[x, y, 0] = color.R;
rgbData[x, y, 1] = color.G;
rgbData[x, y, 2] = color.B;
return rgbData;
Here is one scenario.
Get the byte array of all the pixels like in the post i have mentioned earlier, after that you can do simple math to get location of the first byte for any pixel. That would be your R (RGB) or B (BGR) value.I am not sure if it is stored as RGB or BGR, but it is easy to check.
