Alright, I got the touch code working. It looks like Fezzer is broken, so I will upload it later.
The only issue with pins is that D_IRQ on the shield is D8 as you have stated,but D8 doesn’t support interrupts on Panda,so I have to use thread to poll the touch events.
I’m following your project with great interest and so far it looks very promising.
My first and biggest question is of it also can work on a Fez Mini?
Also looking at your touch interface you report back only the coordinates, does it not give also the press, move, release actions back? (i do not know that ic) just wondering.
@ nielsnl should work but you’ll have to use other pins (UEXT ?!) for the touch interface because (as I can see on the brochure) Mini doesn’t have Di11 to Di13.
LCD needs 12 pins and touch needs 5 pins.
Using UEXT for the touch interface would mean you can use hardware SPI witch is better because the software implementation doesn’t work well if other threads are running.
I got myself two of this iTead displays, do you guys have any new code that is faster then the 1.5 min it is now? I really would like to use those displays but they are really much to slow right now
