I’m slowly getting up to speed on TinyCLR by moving my current .NETMF stuff over. Working on I2C now and I’m getting this error at device.WriteRead (3rd line from the bottom).
I’m guessing it is my usual not understanding something obvious issue but I would appreciate some help finding the problem. Thanks - Gene
using System.Collections;
using System.Text;
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.Storage;
using GHIElectronics.TinyCLR.IO;
using System.IO;
using GHIElectronics.TinyCLR.Devices.I2c;
namespace TinyCLRApplication1
class Program
private const double MilliampsPerCount = 0.5;
private const double VoltsPerCount = 0.025;
static void Main()
Debug.WriteLine("Program Started");
byte[] LTC2946_ADIN_MSB_REG = { 0x28 };
byte[] LTC2946_CONTROLA_REGISTER = { 0x00 };
byte[] LTC2946_DELTA_SENSE_MSB_REG = { 0x14 };
byte[] LTC2946_VIN_MSB_REG = { 0x1E };
byte[] byteArray1X = new byte[1];
byte[] byteArray2X = new byte[2];
var settings = new I2cConnectionSettings(0xDE >> 1); //The slave's address.
settings.BusSpeed = I2cBusSpeed.FastMode;
var controller = I2cController.FromName(UC2550.I2cBus.I2c3);
var device = controller.GetDevice(settings);
device.WriteRead(LTC2946_VIN_MSB_REG, byteArray2X);
double voltage = double.NaN;
voltage = VoltsPerCount * ((byteArray2X[0] << 4) | (byteArray2X[1] >> 4));
