I dont know what happened as it was only running a small program cycling through colors on an RGB LED, and it just died.
I unplugged the USB and back in again. No response from the Domino and my mouse (attached to the same USB hub acted up strange). Tried to power it externally but it draws 1A at 7,5V so something is totally fried here. :’(
Ill have to order me a new one as this was the one paid for by UiO for Whirligig and I was trying to make something for the Halloween contest. With my current luck it wont arrive until the deadline runs out.
:wall:
I have tried that. I even hooked it up to another PC, no go.
As I said. If it draws 1A of current with nothing but the board, -there must be something seriously wrong.
I have already ordered a new one. Hopefully they will send it straight away.
I have noticed if you run the domino and LCD from the 5v direct from the USB there is quite a low voltage present… I think these devices really need at least 4.85v with a decent current supply… I know the domino will be okay on the USB but who knows with an LCD connected the backlight on these take a bit of current…
I always connect to an external supply aswell… Luckily for me my system just froze but things were hot…
It was an common cathode RGB so every color was connected to a IO pin and run with PWM. The cathode was connected to a 220R resistor to ground.
I didn’t know about the 4mA limit on the IO pins, as it’s nowhere to be found in the documentation on this site. I think if you took a poll of the people that has bought FEZ and asked them what the current limit are, few would get the answer right.
But on this note. What is the total current limit for all the IO’s combined? (this must be easy for all you guys that has read the datasheet).
I’m surprised at this… If you had a possible maximum current of 12mA on three pins (I know that sounds like 3 times the allowed current) but if you were feeding them with a pulse width signal it would have been considerably lower and should’nt have died. And even if it did I would have expected one of the colours at least to have failed first…
The datasheet isn’t really clear on current source / sink values the 4mA spec is actually listed as the min value… The short circuit current is listed as 50mA output source and 45mA output sink… I’m afraid that doesn’t give me a definate answer whether this is for seveal pins at a time.
