Those are many notes about the SDK, serialization is not supported on USBizi and this has nothing to do with other items you listed from the release notes
I’ve found the XML classes in NETMF to be a ‘work in progress’. They tend eat up precious memory quickly and we’ve found a bug or two along the way. See [url]http://www.tinyclr.com/forum/1/3488/[/url] for a bug example. That’s not to say you can’t crank out a class that will transform an object into xml. You can, it’s just not as easy as in the full framework.
@ Gus - sorry, must be I was still in day job mode. I do occasionally mix up which classes do what between frameworks and wonder why stuff doesn’t compile!
@ Alex - I have written NETMF that serves up XML over HTTP that can be deserialized by a client running the full framework, but that is obviously not the same thing under the hood :
Here’s a (somewhat dated) quote from Elze Kool’s blog on the topic:
Thanks for the Info ErickH and Gus, I was wondering wich one (serialization); TTL, CMOS, XML, SOAP, ect… or just some. I want to place the small FEZmini in a compact environment, to up link data through Bluetooth, Xbee, Internet, or any other means; to a CPU, Smart Phone, and what not ( I know theres many protocols to do that)
