Hi ,
When I’m trying to add GHIElectronics.NETMF.FEZ; I can’t add that. I also added hardware.dll but I cannot do that …
Hi ,
You are not suppose to be adding that to gadgeteer project. Why do you need to add it?
your tutorial showing that … :S
The tutorial is for non Gadgeteer devices.
Other than that - adding “using” statement is not enough on its own. Make sure you add a reference to the required assembly as well.
