Hydra LCD corruption
Hi All,
I finally connected my Hydra to an 800x600 LCD, but I’m having problems.
The image is corrupted, as if the pixels are in the wrong order. I can almost read the TinyBooter.
As you can see in the second image, the LCD works just fine connected to a G120HDR.
This looks like a memory corruption problem.
Any ideas?
Thank you,
E
PS. Don’t know if the images are going to post…
@ CC - Have you used FezConfig to initialize the LCD?
Hi Mike,
Sorry about the delayed reply. Annoying 7 hours first post delay.
Yes, Used FezConfig for setup.
Same config on both G120 and Hydra.
If I deploy the default Hello World forms application then the Hello World is also corrupted.
Thank you,
E
Try lowering the clock. Try 4mhz.
Hi Gus,
That would give me less than 8fps, and is way out of spec for the display. The display specifies a clock of between 34MHz and 40MHz.
But I will try it tomorrow at 4MHz.
Thank you,
E
Changed the clock to 4MHz.
I would try to reverse the clock and the other signals, just to try and see what happens.
