Hi
I re-write for you
- first learn how to modify a gadgeteer module driver
- Then apply this code below. You can compare with the original one to see the difference, just few lines changed,
add GHI.OSHW.Hardware in your references.
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
using GHI.OSHW.Hardware; // this is for oshw
namespace Gadgeteer.Modules.GHIElectronics
// -- CHANGE FOR MICRO FRAMEWORK 4.2 --
// If you want to use Serial, SPI, or DaisyLink (which includes GTI.SoftwareI2C), you must do a few more steps
// since these have been moved to separate assemblies for NETMF 4.2 (to reduce the minimum memory footprint of Gadgeteer)
// 1) add a reference to the assembly (named Gadgeteer.[interfacename])
// 2) in GadgeteerHardware.xml, uncomment the lines under <Assemblies> so that end user apps using this module also add a reference.
/// <summary>
/// A 7 inch capacitive touch display module for Microsoft .NET Gadgeteer
/// </summary>
/// <example>
/// <para>The following example uses a <see cref="Display_CP7"/> object to display the picture taken by a camera module.
/// First the code initializes a camera object and the button pressed event delegate in which the camera takes a picture.
/// Then, another delegate is initialized to handle the asynchronous PictureCaptured event. In this method the display module uses
/// the SimpleGraphics class to display the picture captured by the camera.
/// </para>
/// <code>
/// using System;
/// using Microsoft.SPOT;
/// using Microsoft.SPOT.Presentation;
/// using Microsoft.SPOT.Presentation.Controls;
/// using Microsoft.SPOT.Presentation.Media;
/// using GT = Gadgeteer;
/// using GTM = Gadgeteer.Modules;
/// using Gadgeteer.Modules.GHIElectronics;
/// namespace TestApp
/// public partial class Program
/// // This template uses the FEZ Spider mainboard from GHI Electronics
/// // Define and initialize GTM.Modules here, specifying their socket numbers.
/// GTM.GHIElectronics.UsbClientDP usbClient = new UsbClientDP(1);
/// GTM.GHIElectronics.Button button = new Button(4);
/// GTM.GHIElectronics.Camera camera = new Camera(3);
/// GTM.GHIElectronics.Display_T35 display = new Display_T35(12, 13, 14);
/// void ProgramStarted()
/// // Initialize event handlers here.
/// button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
/// camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
/// // Do one-time tasks here
/// Debug.Print("Program Started");
/// void camera_PictureCaptured(Camera sender, GT.Picture picture)
/// Debug.Print("Picture Captured event.");
/// display.SimpleGraphics.DisplayImage(picture, 5, 5);
/// void button_ButtonPressed(Button sender, Button.ButtonState state)
/// camera.TakePicture();
/// </code>
/// </example>
public class Display_CP7 : GTM.Module.DisplayModule
/// <summary>
/// The I2C bus that the module will use
/// </summary>
//public static GT.Interfaces.I2CBus i2cBus;
static SoftwareI2CBus softwarei2cBus;
static SoftwareI2CBus.I2CDevice softwarei2cDevice;
const int SDA_PIN = 0; // need to change with your socket, at pin 8
const int SCL_PIN = 0; // need to change with your socket, at pin 9
/// <summary>
/// Constructor
/// </summary>
/// <param name="rgbSocketNumber1">The first R,G,B socket</param>
/// <param name="rgbSocketNumber2">The second R,G,B socket</param>
/// <param name="rgbSocketNumber3">The third R,G,B socket</param>
/// <param name="i2cSocketNumber">The I2C socket</param>
public Display_CP7(int rgbSocketNumber1, int rgbSocketNumber2, int rgbSocketNumber3, int i2cSocketNumber)
: base(WPFRenderOptions.Ignore)
// This finds the Socket instance from the user-specified socket number.
// This will generate user-friendly error messages if the socket is invalid.
// If there is more than one socket on this module, then instead of "null" for the last parameter,
// put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
ReserveLCDPins(rgbSocketNumber1, rgbSocketNumber2, rgbSocketNumber3);
ConfigureLCD();
Socket i2cSocket = Socket.GetSocket(i2cSocketNumber, true, this, "i2cSocket");
//i2cBus = new GTI.I2CBus(i2cSocket, 0x38, 400, this);
softwarei2cBus = new SoftwareI2CBus((Cpu.Pin)SCL_PIN, (Cpu.Pin)SDA_PIN); // add your sda, scl
softwarei2cDevice = softwarei2cBus.CreateI2CDevice(0x38, 100);
// This creates an GTI.InterruptInput interface. The interfaces under the GTI namespace provide easy ways to build common modules.
// This also generates user-friendly error messages automatically, e.g. if the user chooses a socket incompatible with an interrupt input.
this.touchInterrupt = new GTI.InterruptInput(i2cSocket, GT.Socket.Pin.Three, GTI.GlitchFilterMode.Off, GTI.ResistorMode.PullUp, GTI.InterruptMode.RisingAndFallingEdge, this);
// This registers a handler for the interrupt event of the interrupt input (which is bereleased)
this.touchInterrupt.Interrupt += new GTI.InterruptInput.InterruptEventHandler(this._input_Interrupt);
private bool _bBackLightOn = true;
/// <summary>
/// Accessor for the state of the backlight
/// </summary>
public bool BBackLightOn
get { return _bBackLightOn; }
//set { _bBackLightOn = value; }
//private bool _bEnable = true;
///// <summary>
///// Accessor returning if the display is enabled.
///// </summary>
//public bool BEnable
// get { return _bEnable; }
// //set { _bEnable = value; }
private static GTI.DigitalOutput backlightPin;// = new OutputPort(greenSocket.CpuPins[9], true);
private static Socket greenSocket;
//private static OutputPort enablePin;// = new OutputPort(greenSocket.CpuPins[9], true);
//private static Socket blueSocket;
/// <summary>
/// Sets the backlight to the passed in value.
/// </summary>
/// <param name="bOn">Backlight state.</param>
public void SetBacklight(bool bOn)
if (greenSocket != null)
backlightPin.Write(bOn);
_bBackLightOn = bOn;
ErrorPrint("Cannot set backlight yet. RGB sockets not yet initialized");
///// <summary>
///// Sets the backlight to the passed in value.
///// </summary>
///// <param name="bOn">Backlight state.</param>
//public void SetEnable(bool bOn)
// if (blueSocket != null)
// if (bOn)
// enablePin.Write(true);
// else
// enablePin.Write(false);
// else
// ErrorPrint("Cannot set enable pin yet. RGB sockets not yet initialized");
private void ReserveLCDPins(int rgbSocketNumber1, int rgbSocketNumber2, int rgbSocketNumber3)
bool gotR = false, gotG = false, gotB = false;
Socket[] rgbSockets = new Socket[3] { Socket.GetSocket(rgbSocketNumber1, true, this, "rgbSocket1"), Socket.GetSocket(rgbSocketNumber2, true, this, "rgbSocket2"), Socket.GetSocket(rgbSocketNumber3, true, this, "rgbSocket3") };
foreach (var rgbSocket in rgbSockets)
if (!gotR && rgbSocket.SupportsType('R'))
gotR = true;
else if (!gotG && rgbSocket.SupportsType('G'))
gotG = true;
greenSocket = rgbSocket;
backlightPin = new GTI.DigitalOutput(greenSocket, Socket.Pin.Nine, true, this);
else if (!gotB && rgbSocket.SupportsType('B'))
gotB = true;
//blueSocket = rgbSocket;
//enablePin = new OutputPort(blueSocket.CpuPins[8], true);
throw new GT.Socket.InvalidSocketException("Socket " + rgbSocket + " is not an R, G or B socket, as required for the LCD module.");
rgbSocket.ReservePin(Socket.Pin.Three, this);
rgbSocket.ReservePin(Socket.Pin.Four, this);
rgbSocket.ReservePin(Socket.Pin.Five, this);
rgbSocket.ReservePin(Socket.Pin.Six, this);
rgbSocket.ReservePin(Socket.Pin.Seven, this);
//rgbSocket.ReservePin(Socket.Pin.Eight, this);
if (!rgbSocket.SupportsType('G'))
rgbSocket.ReservePin(Socket.Pin.Nine, this);
private void ConfigureLCD()
Mainboard.LCDConfiguration lcdConfig = new Mainboard.LCDConfiguration();
lcdConfig.LCDControllerEnabled = true;
lcdConfig.Width = Width;
lcdConfig.Height = Height;
// Only use if needed, see documentation.
//lcdConfig.PriorityEnable = true;
lcdConfig.OutputEnableIsFixed = true;
lcdConfig.OutputEnablePolarity = true;
lcdConfig.HorizontalSyncPolarity = true;
lcdConfig.VerticalSyncPolarity = true;
lcdConfig.PixelPolarity = false;
lcdConfig.HorizontalSyncPulseWidth = 1;
lcdConfig.HorizontalBackPorch = 46;
lcdConfig.HorizontalFrontPorch = 16;
lcdConfig.VerticalSyncPulseWidth = 1;
lcdConfig.VerticalBackPorch = 23;
lcdConfig.VerticalFrontPorch = 7;
// NOTE: This is used for ChipworkX, comment if using EMX.
lcdConfig.PixelClockDivider = 5;
//dConfig.PixelClockRate = 25000;
// Set configs
DisplayModule.SetLCDConfig(lcdConfig);
/// <summary>
/// Gets the width of the display.
/// </summary>
/// <remarks>
/// This property always returns 800.
/// </remarks>
public override uint Width { get { return 800; } }
/// <summary>
/// Gets the height of the display.
/// </summary>
/// <remarks>
/// This property always returns 480.
/// </remarks>
public override uint Height { get { return 480; } }
/// <summary>
/// Renders display data on the display device.
/// </summary>
/// <param name="bitmap">The <see cref="T:Microsoft.SPOT.Bitmap"/> object to render on the display.</param>
protected override void Paint(Bitmap bitmap)
try
bitmap.Flush();
catch
ErrorPrint("Painting error");
private void _input_Interrupt(GTI.InterruptInput input, bool value)
this.OnTouchEvent(this, null);
private GTI.InterruptInput touchInterrupt;
/// <summary>
/// An enum to describe the possible gestures
/// </summary>
public enum Gesture_ID
/// <summary>
/// A move up gesture
/// </summary>
Move_Up = 0x10,
/// <summary>
/// A move left gesture
/// </summary>
Move_Left = 0x14,
/// <summary>
/// A move down gesture
/// </summary>
Move_Down = 0x18,
/// <summary>
/// A move right gesture
/// </summary>
Move_Right = 0x1C,
/// <summary>
/// A zoom in gesture
/// </summary>
Zoom_In = 0x48,
/// <summary>
/// A zoom out gesture
/// </summary>
Zoom_Out = 0x49,
/// <summary>
/// No gesture detected
/// </summary>
No_Gesture = 0x00
/// <summary>
/// Represents the delegate for when the screen is touched
/// </summary>
/// <param name="sender">The sending module</param>
/// <param name="touchStatus">The class that holds all of the information about interaction with the screen</param>
public delegate void TouchEventHandler(Display_CP7 sender, TouchStatus touchStatus);
/// <summary>
/// Represents the delegate for when the screen's home button has been pushed
/// </summary>
public delegate void TouchEventHandlerHomeButton(Display_CP7 sender);
/// <summary>
/// Represents the delegate for when the screen's menu button has been pressed
/// </summary>
public delegate void TouchEventHandlerMenuButton(Display_CP7 sender);
/// <summary>
/// Represents the delegate for when the screen's back button has been pressed
/// </summary>
public delegate void TouchEventHandlerBackButton(Display_CP7 sender);
/// <summary>
/// Represents the delegate for when the screen has been released
/// </summary>
public delegate void TouchEventHandlerTouchReleased(Display_CP7 sender);
/// <summary>
/// Represents the delegate for when a touch gestur was detected
/// </summary>
/// <param name="id">The ID of the detected gesture</param>
public delegate void TouchGestureDetected(Display_CP7 sender, Gesture_ID id);
/// <summary>
/// Raised when the screen detects a touch
/// </summary>
public event TouchEventHandler ScreenPressed;
/// <summary>
/// Raised when the screen detects a touch on the home button
/// </summary>
public event TouchEventHandlerHomeButton HomePressed;
/// <summary>
/// Raised when the screen detects a touch on the menu button
/// </summary>
public event TouchEventHandlerMenuButton MenuPressed;
/// <summary>
/// Raised when the screen detects a touch on the back button
/// </summary>
public event TouchEventHandlerBackButton BackPressed;
/// <summary>
/// Raised when the screen detects all touches released
/// </summary>
public event TouchEventHandlerTouchReleased ScreenReleased;
/// <summary>
/// Raised when the screen detects a touch gesture
/// </summary>
public event TouchGestureDetected GestureDetected;
private TouchEventHandler onTouch;
private TouchEventHandlerHomeButton onHomePressed;
private TouchEventHandlerMenuButton onMenuPressed;
private TouchEventHandlerBackButton onBackPressed;
private TouchEventHandlerTouchReleased onScreenReleased;
private TouchGestureDetected onGestureDetected;
/// <summary>
/// A class that is responisble for holding information of the current touches on the screen
/// </summary>
public class TouchStatus
/// <summary>
/// An array of positions, one for each detected touch point
/// </summary>
public Finger[] touchPos;
/// <summary>
/// Number of current touches
/// </summary>
public int numTouches;
/// <summary>
/// Constructor
/// </summary>
public TouchStatus()
touchPos = new Finger[5];
/// <summary>
/// Structure that represents a single position
/// </summary>
public struct Finger
/// <summary>
/// X coordinate of the touch position
/// </summary>
public int xPos;
/// <summary>
/// Y coordinate of the touch position
/// </summary>
public int yPos;
/// <summary>
/// Determines if this touch is currently in use.
/// True: this touch is currently registered with the screen
/// False: this touch is not currently registered with the screen
/// </summary>
public bool bActive;
/// <summary>
/// Constructor
/// </summary>
/// <param name="x">X coordinate</param>
/// <param name="y">Y coordinate</param>
/// <param name="active">If the position is active</param>
public Finger(int x, int y, bool active)
this.xPos = x;
this.yPos = y;
this.bActive = active;
bool bSentReleased = false;
/// <summary>
/// Raises events for both the touch positions and touch gestures
/// </summary>
/// <param name="sender">The module that is sending the event</param>
/// <param name="touchStatus">A class that contains all information about the screen</param>
protected virtual void OnTouchEvent(Display_CP7 sender, TouchStatus touchStatus)
int numberOfFingers = (ReadRegister(0x02) & 0xF);
if (numberOfFingers == 0)
if (!bSentReleased)
if (this.onScreenReleased == null)
this.onScreenReleased = new TouchEventHandlerTouchReleased(this.onScreenReleased);
if (Program.CheckAndInvoke(ScreenReleased, this.onScreenReleased, this))
this.ScreenReleased(this);
bSentReleased = true;
return;
int gesture = (ReadRegister(0x01) & 0xFF);
if (gesture != (int)Gesture_ID.No_Gesture)
if (this.onGestureDetected == null)
this.onGestureDetected = new TouchGestureDetected(this.onGestureDetected);
if (Program.CheckAndInvoke(GestureDetected, this.onGestureDetected, this, (Gesture_ID)gesture))
this.GestureDetected(this, (Gesture_ID)gesture);
return;
//Debug.Print("num fingers" + numberOfFingers);
TouchStatus ts = new TouchStatus();
ts.numTouches = numberOfFingers;
for (int i = 0; i < 5; i++)
if (i < numberOfFingers)
int x = ((ReadRegister((byte)(3 + i * 6)) & 0xF) << 8) + ReadRegister((byte)(4 + i * 6));
int y = ((ReadRegister((byte)(5 + i * 6)) & 0xF) << 8) + ReadRegister((byte)(6 + i * 6));
ts.touchPos[i] = new Finger(x, y, true);
// HEY LISTEN
// DO THE BUTTON THINGS RIGHT HERE
// Check to see if a user has used one of the "Android" buttons
if (x > 800)
if (y >= 0 && y <= 50)
// Home
if (this.onHomePressed == null)
this.onHomePressed = new TouchEventHandlerHomeButton(this.onHomePressed);
if (Program.CheckAndInvoke(HomePressed, this.onHomePressed, this))
this.HomePressed(this);
if (y >= 100 && y <= 150)
// Menu
if (this.onMenuPressed == null)
this.onMenuPressed = new TouchEventHandlerMenuButton(this.onMenuPressed);
if (Program.CheckAndInvoke(MenuPressed, this.onMenuPressed, this))
this.MenuPressed(this);
else if (y >= 200 && y <= 250)
// Back
if (this.onBackPressed == null)
this.onBackPressed = new TouchEventHandlerBackButton(this.onBackPressed);
if (Program.CheckAndInvoke(BackPressed, this.onBackPressed, this))
this.BackPressed(this);
ts.touchPos[i] = new Finger(-1, -1, false);
//Debug.Print("X: " + x + " Y: " + y);
if (this.onTouch == null)
this.onTouch = new TouchEventHandler(this.OnTouchEvent);
if (Program.CheckAndInvoke(ScreenPressed, this.onTouch, sender, ts))
this.ScreenPressed(sender, ts);
static byte ReadRegister(byte Address)
int numwrite;
int numread;
byte[] RegisterAddress = new byte[1] { Address };
byte[] RegisterValue = new byte[1];
softwarei2cDevice.WriteRead(RegisterAddress,0,1,RegisterValue,0,1,out numwrite, out numread);
return RegisterValue[0];
