I’ve just read the how-to to upgrade the firmware on the Hydra and a question comes in mind : GUS says that we should put MISO to GND in order to begin the process. Not more than 5 sec. Fine.
But… it also means that we won’t be able to use (at least) PA25 pin with a pulldown resistor in usual programs ? ???
Right now it’s not a problem because ResistorMode.Pulldown is throwing an exception at runtime, but I think it also implies that Pulldown may not be available at all for all other pins as well, which is somehow embarassing, I think.
Am I wrong ?
You are mixing things. Connecting miso to ground will block the processor from reading flash memory and so it ends up running atmel samba software which will give you a new virtual com port.
Sorry if I look like silly, but unless I miss something your answer seems to indicate that I can’t use the pin PA25 (on connector 3 or 4, see below) as a digital IO with a pulldown resistor.
In this case, as I understand it, the board won’t load the application but a bootloader. Because MISO has been pulled to ground.
Btw, is there only one SPI ? I ask that because connectors 3 & 4 are sharing the same MISO/MOSI pins on the schematics. Nothing wrong here, only curiosity
You are adding the wire ONLY and only for 5 seconds to update the firmware and this is ONLY done now since we do not have an adapter application.
So, why do you think you can’t use those pins?
To be more clear, this is a temporary thing for “beta testers”. We are still making all kind of cool things for it, including a firmware update application. In which this is open source so feel free to contribute if you are interested.
Why didn’t you say that before ?
I thought it was a permanent way of doing updates (though not really user-friendly).
Btw, it worked, so I won’t complain that much…
Now I don’t think this anymore… :-[
Thank you !
Glad it is clear now
Enjoy your FEZ Hydra
Can’t we use internal pulldown resistors on Hydra? It thows an exception. I tried sockets 3,4,7,9.
Edit: 4.1 project
This processor does not have pull down.
