Ok. I will implement a workaround and read / write the signals in units of 7 pins (byte for byte). As template, I’ll use the original source file by GHI. Maybe it’s also a good idea for the new SDK to read / write a complete byte?
But is this a known problem?
You found the problem?
@ mtylerjr - No, I will use the “HubAP5_32.cs” file to communicate directly with the hub.
@ John - Is this a known problem?
Given he stated it’s fixed, that would imply it’s known. Why do you ask ?
@ Brett - I want to know, whether this problem is now known or was already known.
@ Michael.62 - It was fixed about a month ago when we made some I2C improvements for the next SDK actually.
