HttpRequest reseived problem
i have received a http request and want to write the datas to a file (binary)
that me code (VB) to read the buffer
 Private Sub mvarWebClient_ResponseReceived(ByVal sender As Gadgeteer.Networking.HttpRequest, ByVal response As Gadgeteer.Networking.HttpResponse) Handles mvarWebClient.ResponseReceived
                    Dim SDbuffer(1) As Byte
                        Do
                            SDbuffer(0) = response.Stream.ReadByte()
                            SDfile.Write(SDbuffer, 0, 1)
                            Debug.Print( response.Stream.Position.ToString + "  " + response.Stream.Length.ToString)
                        Loop Until response.Stream.Position = response.Stream.Length - 1
The problem is the stream.position allways point to the first byte i have received.
The debug.print allways print “0 22720” and the buffer allways contains the first byte from the resonse
