Hi
I made simple test application with http listener, based on Ethernet and Http server tutorials.
I tested it using Postman Runner with 1000 iterations test (with delay 3 sec)
It works with only few replies delayed - response time is less then 200 ms, but had few responses with reply time more then 15 sec!
But - every few attempts I got exceptions:
112
116
RawUrl: /api/on
Command: on
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (5) ####
#### Message:
#### System.Net.OutputNetworkStreamWrapper::Flush [IP: 0014] ####
#### System.Net.HttpListenerResponse::System.IDisposable.Dispose [IP: 0018] ####
#### Message:
#### Message:
#### Message:
112
116
RawUrl: /api/off
Command: off
#### Message:
112
116
RawUrl: /api/on
Command: on
112
116
RawUrl: /api/off
Command: off
112
116
RawUrl: /api/on
Command: on
112
116
RawUrl: /api/off
Command: off
112
116
RawUrl: /api/on
Command: on
112
116
RawUrl: /api/off
Command: off
Exception doesn’t brake program excecution - I can’t catch it either within my try.
Can you tell me what could be wrong. For me it looks like smth is going wrong within HttpListener class.
Here is my code:
using GHIElectronics.TinyCLR.Networking;
using GHIElectronics.TinyCLR.Devices.Network;
using System.Net;
namespace Httptest
public static class Http
public static void Start()
//Create a listener.
HttpListener listener = new HttpListener("http", 80);
listener.Start();
var clientRequestCount = 0;
try
//Note: The GetContext method blocks while waiting for a request.
HttpListenerContext context = listener.GetContext();
//Obtain a response object.
HttpListenerResponse response = context.Response;
//Construct a response.
var responseString = string.Format("<HTML><BODY> I am TinyCLR OS Server. " +
"Client request count: {0}</BODY></HTML>", ++clientRequestCount);
byte[] buffer = System.Text.Encoding.UTF8.GetBytes(responseString);
//Get a response stream and write the response to it.
response.ContentLength64 = buffer.Length;
var output = response.OutputStream;
System.Diagnostics.Debug.WriteLine("112");
output.Write(buffer, 0, buffer.Length);
System.Diagnostics.Debug.WriteLine("116");
//You must close the output stream.
output.Close();
//geting command from request
HttpListenerRequest request = context.Request;
if (request.RawUrl.Length > 0)
System.Diagnostics.Debug.WriteLine("RawUrl: "+request.RawUrl);
string[] strParams = request.RawUrl.Substring(1).Split('/');
//var method = request.HttpMethod;
if (strParams[0].Length > 0 && strParams[0] == "api")
if (strParams.Length >= 2)
switch (strParams[1])
case "beep":
break;
case "on":
System.Diagnostics.Debug.WriteLine("Command: "+strParams[1]);
break;
case "off":
System.Diagnostics.Debug.WriteLine("Command: " + strParams[1]);
break;
catch (OutOfMemoryException ex1)
throw new OutOfMemoryException("Exc at 01: " + ex1.Message);
catch (Exception ex)
listener.Stop();
