Flid
1
All is in topic
How make one update of exe, in PANDA (or other), without run VS10 and make one deploy :
Why this question :o
Because:
- I don’t want that the code source can’t be visible by updater …
- I want make one procedure easy for one customer…
Best Regards
Is this what you are wanting to do? http://www.tinyclr.com/forum/2/6001/
Flid
3
Yes, but when I try:
Target / Application deployement / Create Application deployement
I have: Device has old or unsupported configuration ???
Please see USBizi user manual. The bootloader has commands to create a master copy and to load new devices without the need fro VS2010.
Flid
5
Ok, if I understand
On my Panda I read the flash memory with G command, in one file,
and after my customer,on his Panda, can update, by write this file with L command.
I’m right ?
