The following code i already have (found in an other forum post):
const int HID_DESCRIPTOR_TYPE = 0x21;
ushort myVID = 0x03F0;
ushort myPID = 0x0324;
ushort myDeviceVersion = 0x100;
ushort myDeviceMaxPower = 70; // in milli amps
string companyName = "Hewlett-Packard";
string productName = "HP Basic USB Keyboard";
string myDeviceSerialNumber = "0";
USBC_Device device = new USBC_Device(myVID, myPID, myDeviceVersion, myDeviceMaxPower, companyName, productName, myDeviceSerialNumber);
// Endpoints
byte writeEPNumber = device.ReserveNewEndpoint();
byte readEPNumber = device.ReserveNewEndpoint();
MS.Configuration.Endpoint[] epDesc = {
new MS.Configuration.Endpoint(writeEPNumber, MS.Configuration.Endpoint.ATTRIB_Write | MS.Configuration.Endpoint.ATTRIB_Interrupt),
new MS.Configuration.Endpoint(readEPNumber, MS.Configuration.Endpoint.ATTRIB_Read | MS.Configuration.Endpoint.ATTRIB_Interrupt),
epDesc[0].wMaxPacketSize = 8;
epDesc[0].bInterval = 18;
epDesc[1].wMaxPacketSize = 8;
epDesc[1].bInterval = 18;
byte[] hidGenericReportDescriptorPayload = new byte[]
0x05, 0x01, //Usage Page (Generic Desktop) 05 01
0x09, 0x06, //Usage (Keyboard) 09 06
0xA1, 0x01, //Collection (Application) A1 01
0x05, 0x07, // Usage Page (Keyboard/Keypad) 05 07
0x19, 0xE0, // Usage Minimum (Keyboard Left Control) 19 E0
0x29, 0xE7, // Usage Maximum (Keyboard Right GUI) 29 E7
0x15, 0x00, // Logical Minimum (0) 15 00
0x25, 0x01, // Logical Maximum (1) 25 01
0x95, 0x08, // Report Count (8) 95 08
0x75, 0x01, // Report Size (1) 75 01
0x81, 0x02, // Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
0x81, 0x01, // Input (Cnst,Ary,Abs) 81 01
0x05, 0x08, // Usage Page (LEDs) 05 08
0x19, 0x01, // Usage Minimum (Num Lock) 19 01
0x29, 0x03, // Usage Maximum (Scroll Lock) 29 03
0x95, 0x03, // Report Count (3) 95 03
0x91, 0x02, // Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
0x95, 0x01, // Report Count (1) 95 01
0x75, 0x05, // Report Size (5) 75 05
0x91, 0x01, // Output (Cnst,Ary,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 01
0x19, 0x00, // Usage Minimum (Undefined) 19 00
0x2A, 0xFF, 0x00, // Usage Maximum 2A FF 00
0x26, 0xFF, 0x00, // Logical Maximum (255) 26 FF 00
0x95, 0x00, // Report Count (6) 95 06
0x75, 0x08, // Report Size (8) 75 08
0x81, 0x00, // Input (Data,Ary,Abs) 81 00
0xC0, //End Collection C0
byte[] hidClassDescriptorPayload = new byte[]
0x01, 0x00, //bcHID
0x00, //bCountryCode
0x01, //bNumDescriptors
0x22, //bDescriptorType (report)
(byte)hidGenericReportDescriptorPayload.Length, 0x00
MS.Configuration.ClassDescriptor hidClassDescriptor = new MS.Configuration.ClassDescriptor(HID_DESCRIPTOR_TYPE, hidClassDescriptorPayload);
MS.Configuration.UsbInterface usbInterface = new MS.Configuration.UsbInterface(1, epDesc);
usbInterface.classDescriptors = new MS.Configuration.ClassDescriptor[] { hidClassDescriptor };
usbInterface.bInterfaceClass = 0x03; // HID
usbInterface.bInterfaceSubClass = 0x00;
usbInterface.bInterfaceProtocol = 0x00;
// Attach interface
byte interfaceIndex = device.AddInterface(usbInterface, "HP Basic USB Keyboard");
MS.Configuration.GenericDescriptor hidGenericReportDescriptor = new MS.Configuration.GenericDescriptor(0x81, 0x2200, hidGenericReportDescriptorPayload);
hidGenericReportDescriptor.bRequest = 0x06;
hidGenericReportDescriptor.wIndex = 0x00;
device.AddDescriptor(hidGenericReportDescriptor);
// Strings
MS.Configuration.StringDescriptor stringDescriptor1 = new MS.Configuration.StringDescriptor(1, "USB-Eingabegerät");
MS.Configuration.StringDescriptor stringDescriptor2 = new MS.Configuration.StringDescriptor(2, "HP Basic USB Keyboard");
device.AddDescriptor(stringDescriptor1);
device.AddDescriptor(stringDescriptor2);
USBC_Stream stream = device.CreateUSBStream(writeEPNumber, readEPNumber);
USBClientController.Start(device);
byte[] send = Encoding.UTF8.GetBytes("test");
stream.Write(send, 0, send.Length); // <-- does not work
The gadgeteer is coming up as keyboard in device manager already. But i dont know how to write with the stream like as someone is typing the keyboard. Is it possible?
Thanks for any help
