Tutorial to setup Porting Kit and ARM RVDS compiler.
1st step.
Make sure that msbuiild is properly set. Open command prompt and type msbuild. If you got the message, āmsbuildā is not recognized as an internalā¦, you need to add or change Path for MSBuild in Environment Variables of your system. In my case I added the path:
2nd step.
Download and install Porting Kit 4.2 (RTM QFE2):
Make sure that you dont have installed other versions of Porting Kits.
I would suggest installing Porting Kit into default location as [quote]C:\MicroFrameworkPK_v4_2[/quote]
Just in case if something will go wrong, create backup copies of 2 folders:
and
Download source code of Cerberus firmware from:
http://ghiopensource.codeplex.com/
From downloaded zip file copy the folders Solutions to
and DeviceCode to
[quote]C:\MicroFrameworkPK_v4_2\DeviceCode[/quote].
If some files already existing, just overwrite them.
3rd step
RVDS is pretty expensive software. But you can use for one month full functional trial version.
Go to the http://www.arm.com/ and create an account.
After account verification and site authorization, go to the downloads section:
Downloads - Arm Developer ā Development Tools ā RVDS and download the file RealView Development Suite (RVDS) 4.1 Professional
During installation process, there would be popup message, asking you to select Ethernet interface. Copy somewhere the number of your network interface.
Go to the Downloads - Arm Developer website again, Licensing->Eval Products->Evaluation Products->Development Studio 5 (DS-5)
Provide all information required and select: View license and save license file or text to license.lic file. I donāt know why, but I had the problems when license file with default .dat extension.
4th step.
Just in case, create a copy of setenv_base.cmd file
Go to the http://netmf.codeplex.com/workitem/777, and from attachment download the file RVDS_v4_1.zip
Extract files to C:\MicroFrameworkPK_v4_2\
I know this is not right solution, but that way resolving many problems with PATH variables and files locations.
Create the folders structure:
[quote]C:\MicroFrameworkPK_v4_2\tools\ads_v4_1
C:\MicroFrameworkPK_v4_2\tools\ads_v4_1\BIN
C:\MicroFrameworkPK_v4_2\tools\ads_v4_1\licenses[/quote]
Copy into C:\MicroFrameworkPK_v4_2\tools\ads_v4_1\license your license.lic file
Copy to C:\MicroFrameworkPK_v4_2\tools\ads_v4_1\BIN all files from C:\Program Files\ARM\RVCT\Programs\4.1\713\win_32-pentium for 32 bits compiler or C:\Program Files\ARM\RVCT\Programs\4.1\713\win_32-x86_64 for 64 bits compiler.
Open in text editor setenv_base.cmd file, and find the line:
On my file its looks: set ARMLMD_LICENSE_FILE=%ARMROOT%\licenses\license.lic
5th step
Open command prompt, change location to C:\MicroFrameworkPK_v4_2 and type: [quote]setenv_base.cmd RVDS4.1[/quote]
Type in command prompt: armcc.exe.
If everything is set right, you should see the message ARM C/C++ compilerā¦ Your license ā¦ will expireā¦
Now you are ready to compile firmware.
Type in command prompt: [quote]msbuild C:\MicroFrameworkPK_v4_2\Solutions\FEZCerberus
dotnetmf.proj /p:flavor=release[/quote]
Make a cup of coffee and wait.
If after compilation you will see warning messages, just ignore them. If you will see errors, redirect msbuild messages to some text file to found out the problems.
In C:\MicroFrameworkPK_v4_2\BuildOutput\THUMB2\RVDS4.1\le\FLASH\release\FEZCerberus\bin\tinyclr.hex folder you will find compiled firmware.
Still I didnt find the way, how to compile the Cerberus firmware with Ethernet support. I hope somebody from the community or GHI will help with that problem.
In C:\MicroFrameworkPK_v4_2\tools\bin\SolutionWizard you can find SolutionWizard.exe application. Not the best software, but you can use it to clone or edit existing solutions. At least to see what is going on inside the project.
Also you can download NETMF source code from http://netmf.codeplex.com and in the folder client_v4_2_comm\tools\bin\PKStudio you will find PKStudio software to manage firmware solutions. Only the problem, I couldnt make to compile under PKStudio. But still worth to look.
Helpful links:
http://www.ghielectronics.com/downloads/FEZ/Beginners%20Guide%20to%20Porting%20NETMF.pdf
http://www.netmf.com/working-with-the-net-mf-porting-kit-v41.aspx
http://netmf.codeplex.com/wikipage?title=The%20.NET%20MF%20Codeplex%20Distribution%20HowTo%20Manual
http://netmf.codeplex.com/documentation
http://www.mountaineer.org/app/download/6083569375/NETMF+for+STM32+-+Tour+d'Horizon.pdf?t=1339779332
Great tutorials about debugging NETMF boards on native code level.
Hope my information helps and good luck with compiling
