How to change the readings from a compass to ,
North,
South
West
and East.
Please advice
North,
South
West
and East.
Please advice
You can read the angle value and if is in the certain range you can treat it as a North or any other direction you want.
Edit:
Something like:
N: 337.5 <= angle < 22.5
NE: 22.5 <= angle < 67.5
E: 67.5 <= angle < 112.5
@ Architect - Do you have a complete code for this ?
No, but it is really simple. Something like this:
public static string GetDirection(double angle)
if (angle >= 337.5 || angle < 22.5)
return "N";
else if (angle >= 22.5 && angle < 67.5)
return "NE";
else if (angle >= 67.5 && angle < 112.5)
return "E";
else if (angle >= 112.5 && angle < 157.5)
return "SE";
else if (angle >= 157.5 && angle < 202.5)
return "S";
else if (angle >= 202.5 && angle < 247.5)
return "SW";
else if (angle >= 247.5 && angle < 292.5)
return "W";
return "NW";
You have to check what angle value is N for your compass. The function above is for 0(360) being North. If compass returns different angle for North then you just need to rotate return values accordingly.
@ Architect - does that first line work?
Should be or not and?
@ Justin - Thanks for proofing! You are right the first one should be OR. I will modify it.
@ Architect - your most welcome, its usually me needing the proofing
Updated the code.
