How to download the GHI Electronics NETMF Documentation and NETMF API Reference in local computer
Dear Sir:
How can I download the GHI Electronics NETMF Documentation and NETMF API Reference in local computer.
Because it is not possible that I aways have the internet.
Thank you
Lin
For the GHI Electronics NETMF Documentation:
You can right-click the GHI Electronics NETMF Documentation link and select “save target as…” and then you can download the PDF to your pc.
For the NETMF API Reference:
You will need to save the whole page contents to your pc. You can do this by using (for example) a program like this one:
If you cannot get it to work, please let me know.
Regards
You don’t need to download , it is already on your pc B)
GHI Documentation is located as CHM File under
C:\Program Files\GHI Electronics\Embedded Master SDK 3\Documentation\Library
And the MS Framework documentation is installed automatically with the SDK installtion
It is available in Visual Studio help system (just press F1 and you will see it on the right side)
Best regards
Cypher
For the 4.0 SDK, it’s located here :
\Program Files\GHI Electronics\GHI NETMF v4.0 SDK\Assemblies\Documentation\GHI Electronics NETMF Library Documentation.chm
