My point exactly. Please re-read my post.
Truth Table time
A = (ud != 0x54)
B = (ud != 0x55)
where ud = 0x54⌠A = FALSE, B= TRUE, A && B = FALSE
where ud = 0x55⌠A = TRUE, B = FALSE, A && B = FALSE
where ud = anything else⌠A = TRUE, B = TRUE, A && B = TRUE.
so the code as shown:
if (ud != 0x55 && ud != 0x54)
this.ErrorPrint("Setting the display configuration failed.");
will trigger the error display when ud isnât returned as 0x54 or 0x55. You need to check what the return value is and see what that really means (datasheet time)
Edit: this code just makes more sense as:
if (!(ud == 0x55 || ud == 0x54))
@ Brett - De Morganâs Law to the rescue!
ok driver for :
-RFIDReader
-XbeeAdapter
-PulseOximeter
are readyâŚ
get it from GitHub - Gravicode/GadgeteerToTinyCLR: This is our effort to port gadgeteer modules/mainboards to TinyCLR
Thanks to Dave for xbee module. ![]()
I need some help, in some method in serial cam L1 driver, it is always throw an exception⌠I have added more delay, still errorâŚ
This method will read sequential data from camera with UART
I would hold on using serial until we bring back G400 to TinyCLR.
Thankyou, this worked to update bootloader, was always showing 2.0.1 even after transfer.
Even in the video (very nice video, thanks mif) the xmodem transfer seems to time out?
Was it successful?
After upgrading to Bootloader 2.0.2 and Firmware 0.4.0 (tried 0.3.0 also) Im still having trouble deploying assemblies to the G400 Raptor.
Using Nuget Packages v0.4.0
Seems to suggest Firmware is not correct, but I did appear to successfully update to v0.4.0
How can I tell what version of firmware is actually running?
VS2017 Output:-
Found debugger!
Create TS.
Loading start at 2005e600, end 2005e68c
Assembly: mscorlib (0.0.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: G400TinyCLR4 (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Core (0.4.0.0)
Error: the reference GHIElectronics.TinyCLR.Core cannot be used with this version of the firmware.
Please make sure your firmware and references have the same major and minor version.
Firmware checksum 0xB6206F22 does not match the assembly checksum 0x406CD440.
Resolving.
Assembly: G400TinyCLR4 (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Coreâ (0.4.0.0)
Error: a3000000
Waiting for debug commandsâŚ
The program â[7] TinyCLR application: Managedâ has exited with code 0 (0x0).
You do not have the correct assemblies. Do you have everything 0.4.0 installed, including the extension? Did you start a new project?
Thankyou!
So Tried on G120, same result
Updated G120 to TinyClr 0.4.0
New Project
(Defaulted to 0.5.0 TinyCLR.Core (as have 3/4/5 local NuGet)
DownGraded to v0.4.0
Built
Deployed and get same on G120, Im missing something obvoius?
Checked Reference in Object Browser and it shows GHIElectronics.TinyCLR.Core runtime version v4.0.30019 and Version 0.4.0.0
VS2017
Found debugger!
Create TS.
Loading start at 41ab0, end 41b3c
Assembly: G120TinyCLR4 (1.0.0.0) Attaching deployed file.
Resolving.
Assembly: G120TinyCLR4 (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Coreâ (0.4.0.0)
Error: a3000000
The program â[10] TinyCLR application: Managedâ has exited with code 0 (0x0).
Re-installed VS Extention and says âAlready Installedâ
Uninstall the extension first.
Thanks for your time, appreciated! Really want to get this going on either G400 or G120 boardâŚ
Hmmm, Yes VS2017 Preview it did say I had âTiny CLR OS Project Systemâ 0.5.0 Installed.
Interesting, as if I look at the TinyCLR 0.5.0 dowload ZIP I had it doesnât contain a .vsix extention so not sure where I got the new 0.5.0 extension from. Maybe an Auto Upgrade?
So now running Extension 0.4.0
But same result.
Also have re-burn Bootloader and Firmware for G120 G120 Firmware.0.4.0.ghi several times nowâŚ
I must be stupid!
How can I tell what version of the Firmware has been burnt into the SOC?
HANG on!!!
Reset G120 and Now working!!!
I am stupid!
Sorry to waste your time.
Wonder where the 0.5.0 VS vsix Extention came fromâŚ
I didnât un-install it because I assumed that the vsix extention was just deployment tooling only and not tied to a âSDKâ version, my wrong assumption.
Does this extension force the 0.5.0 assemblies to be linked? Even though Im referencing 0.4.0 ??
Hello! I am beginning my attempts to use the drivers from that repository.
The example (TinyApp) links to TinyCLR references v 0.4.0 - it wasnt that difficult to get it to all build with 0.6.0 (just removing a reference to G400s.i2sbus I think
However I ran into my first stumbling block trying to use the TestMotor() / MotorDriverL298 object
The example shows use with a FEZRaptor, but when I change to FEZReaper, there looks to be a completely different abstraction for the PWM items in the associated socket items in the Reaper object vs the Raptor object.
Can anyone see how one could instantiation a MotorDriverL298 using a FEZReaper instead of a FEZRaptor?
Existing sample:
static void TestMotor()
MotorDriverL298 motor = new MotorDriverL298(FEZRaptor.Socket18.PwmPin.Controller0.Id, FEZRaptor.Socket18.PwmPin.Controller1.Id,
FEZRaptor.Socket18.PwmPin.Controller0.PC18, FEZRaptor.Socket18.PwmPin.Controller1.PC19, FEZRaptor.Socket18.Pin6, FEZRaptor.Socket18.Pin9);
motor.SetSpeed(MotorDriverL298.Motor.Motor1, -0.8);
motor.SetSpeed(MotorDriverL298.Motor.Motor2, -0.8);
(The FEZReaper.Socket objects do not have PwmPin)
Time to RTFM ![]()
http://docs.ghielectronics.com/tinyclr/tutorials/pwm.html
For example, PwmController.FromId(FEZ.PwmPin.Controller4.Id) should start you down the South Island Garden Path you were looking for - just donât stop for any hobbits you see!
