I’d like to attach an external circuit to my spider board and get informed, wenn the external circuit is closed. So I tried to use the GPIO and Interrupts. I connected the external GPIO to the Pins 1 and 3 of a X Socket to get the OnInterrupt Event. But when I close my circuit nothing happens. What did I wron?
Here’s my code and attached you’ll find a more than simple circuit diagram how I connected the circuit to the socket.
using MSH = Microsoft.SPOT.Hardware;
public partial class Program
MSH.InterruptPort m_Interrupt;
m_Interrupt = new MSH.InterruptPort(MSH.Cpu.Pin.GPIO_Pin1, false, MSH.Port.ResistorMode.PullUp, MSH.Port.InterruptMode.InterruptEdgeBoth);
m_Interrupt.OnInterrupt += (data1, data2, time) => { Debug.Print("Yeah! Interrupt!"); };
When your switch closes you are shorting the 3V supply.
Check out what Jason suggest.
The normal convention to detect a switch is to use a pullup to VCC and then the switch shorts the input to GND. You can then detect this in software.
On some microcontrollers you even have built in pullups that can be used when there is short wiring between the input and the switch.
If you are using interrupts to detect the switch remember that switches bounce so you may see multiple pressed for one press. You can handle this in you code with suitable timing. Is around 10-30 ms in general.
