Hello.
My equipement is a ghi component shield v2 ,DHT11 , fez panda(original) and a JST3AA for connections. I want to use this: http://code.tinyclr.com/project/339/dht11-temperature-sensor-using-rlp/
It says [quote]Source Code[/quote].How do I install the driver to use the code.
The source code is the “driver”.
The usage example show how you can use the driver in your code.
Note it’s in RLP. So not C#.
If you can’t see the code, you must click the +.
See screenshot below.
