We are working on that still but most of it is easy to figure out and we are here to help. Start with BrainPad. And you will get a list of available options.
@GHI… When the Bluetooth modules come out for the new GHI Products and I guess it will be a 4.0 or the new 5.0 series, don’t know; but can you guys also bring out a Bluetooth 2.0 series module because 2.0 is the only one that can transfer “Audio” over Bluetooth so far and please break out all the pins like Sparkfuns RN41 Bluetooth break out module or similar. … Thanks
Why not simply wire the sparkfun board if it does what you need?
@Gus_Issa… yeah your right Gus… but … because it will make using your products easier, you don’t have to have wires all over the place or make a custom pcb just to plug and play Bluetooth 2.0 series …, say for example you guys make a bluetooth module for the brainpads socket, it will be easier to plug and play.
Thanks Gus
Isn’t the Brainpad-socket just a Click-socket, where millions (nearly) of modules are available?
This is where we design a custom board just for you, assuming commercial use.
basically yes
