Now I wonder how to hookup to test. I was thinking of using std headers pointing down for breadboard, but the holes too small. Even 22g wire is too big. How you guys typically hookup such stuff for prototype with eye toward using permanent? tia
I usually solder on a header to the board then wire to my test jig using solder-less breadboard jumper wires. I keep a variety of M/M, M/F, F/F wires on my bench for this. the male pins will fit directly into the headers on the FEZ. Then when I am ready for making it more permanent, I wire up a cable using crimp connectors.
Thanks Arc and blue. Not to beat a horse. But my basic bread board says 20-29g wire. Will the 30 be too thin to stick? Also, are those headers same size as ones sold on fez, or small diameter. Stats not on this site to compare what the diff is. tia
You can also use 22 AWG stranded wire. Cut individual coper threads on one end until it will fit into the hole on you break out board and solder male header pin on the other end to stick it into the bread board.
