i have developed a vast application in NETMF using SDK 4.1, GHI SDK 4.1 and Innobedded controls 1.2, i need hibernate mode into my application but i have faced many problems to achieve hibernate mode, problems are as follows
NETMF SDK 4.1 does not support hibernate mode, SDK 4.2 support hibernate mode.
To make my application in SDK 4.2 i need support of GHI SDK 4.2 and Innobedded 1.2, but i am not getting fully support from GHI SDK 4.2 for some of methods (assemblies) , i also not getting fully support from Innobedded 1.2
Can anyone help me what should i do ?
Can NETMF 4.1 support hibernate mode, so that my work can easily be done, because i m fully comfirtable with NETMF 4.1 SDK
i have tried it,
it did not support
i need solution to continue with my current developed code in 4.1 itself
re-write whole code into 4.2 in same architecture its very lengthy and time consuming process for me
please provide the code of what you tried. As Gus says, if you’ve tried to do this in a small sample code you will easily be able to show that, and people will then be able to assist. You will need to be specific about “it did not support” means, please describe any error/s or behaviours in detail.
but noone error is coming while i use hibernate code in 4.1 SDK,
as this SDK does not support hibernate mode,
its goes into hibernate and could not wakeup in small application too, only this kind of problem i m facing,
