@ Dat
You’re code works if I use Fez Config to configure LCD as T35. But the big problem is that I am using LCD io’s for other purpose (at the beginning of my application I am performing:
bool cfg_chg = Configuration.LCD.Set(Configuration.LCD.HeadlessConfig);
// to use the LCD reserved IOs, return true if config has changed false otherwise.
if (cfg_chg)
PowerState.RebootDevice(false); //hard reboot
Therefore how to configure LCD as T35 after that?
EDIT I am just trying to put values shown by FEZConfig and will let U know
Ok here’s the test code:
//using GHI.Pins;
//using GHI.Processor;
using GHI.Premium.Hardware;
using GHI.Premium.Hardware.LowLevel;
using GHI.Hardware.EMX;
namespace EMX_TestInterruptHibernateUser
static OutputPort LED = new OutputPort((GHI.Hardware.EMX.Pin.IO9), true);
static InterruptPort bp = new InterruptPort(GHI.Hardware.EMX.Pin.IO18, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
static InputPort buttontest = new InputPort(GHI.Hardware.EMX.Pin.IO17, false, Port.ResistorMode.PullUp);
public static void bp_on_interupt(uint port, uint state, DateTime time)
Debug.Print("Wakup ");
if (cfg_chg)
bp.EnableInterrupt();
bp.OnInterrupt += new NativeEventHandler(bp_on_interupt);
GHI.Premium.Hardware.LowLevel.Watchdog.Enable(30000);
Debug.Print("ALIVE");
GHI.Premium.Hardware.LowLevel.Watchdog.ResetCounter();
LED.Write(!LED.Read());
Thread.Sleep(500);
if (buttontest.Read() == false)
Configuration.LCD.Configurations lcdConfig = new Configuration.LCD.Configurations(320, 240, true, true, false, false, true, 41, 27, 51, 10, 8, 16, 9000);
Configuration.LCD.Set(lcdConfig);
Debug.Print("Sleep mode");
Power.Hibernate(Power.WakeUpInterrupt.InterruptInputs);
This does not work and I can not figure out why. It seems that setting the LCD crash the system. no interrupt awakes the platform but the watchdog yes! is it a bug or something I am doing wrong! I do not see this bug reported in the documentation.
If hibernation can not be done unless using an LCD then there’s a serious problem!
Having a look on the 4.2 release note, it says that low power mode is not supported… whereas your test code shows we can enter in hibernate mode. Having a look on the GHI Premium library (4.2) we can see that Configuration takes effect after reboot… is it the cause of my problem?
@ leforban -
is it easy to upgrade to 4.3 with your project?
Nop I don’t have VS2012 because my computer is on Vista…
@ andre I know but can’t laugh. I extremely need to fin a solution for that and can’t buy a new computer and migrate the project within a week.
