Just received my FEZ spider and I am having issues getting my computer to recognize it when plugged in to the USB (through the DP client module).
The device powers up (red light on both main board and module) however the computer does not see the device.
Tried MFdeploy with no effect.
If you mean what are the max amps that your power supply can provide then there really is no max. What really matters is how much current (amps) you are actually using. If you’re just using commercial Gadgeteer modules and not doing any of your own circuits with the Extender module then this isn’t really something you should have to worry about. If you have a 5A wall wart supply around then that should work just fine as long as it’s the correct voltage.
Running into the same issue on a new Spider board I just got. On one machine when I plug it in to USB, nothing happens at all on the PC (no USB connection sound, no indication that the PC sees the Spider at all), although the USB Client DP and the Mainboard LEDs both light up. Tried the firmware updater, but it can’t see the board, nor is the board showing up in MFDeploy.
On a second machine, I do get the USB connect sound, but it says that the USB device has malfunctioned and cannot be recognized. Tried uninstalling from device manager and plugging it in fresh…no luck. Tried firmware update from the 2nd machine, still could not see the board (and yes, in both cases, I set the switches for firmware update mode).
In all of my attempts, I’m connecting direct, no USB hubs, and I’ve tried both USB alone, as well as USB + separate wall wart to ensure there was plenty of power.
Any suggestions in terms of troubleshooting would be welcome.
Sorry for my ignorance, but how do I know which pin to check? Is this documented somewhere?
Also, some additional info…if I have the T35 display attached, it does display the tinybooter info, so I’m pretty sure the board isn’t completely dead.
Further weirdness. My original Spider board, which was working fine, and which showed up as a GHI debuggable device (or something like that) is now showing the same symptom when connecting via USB.
I was originally attempting to build out the Gadgeteer Arcade console, which is when the new board started acting hinky. Then I swapped in my known good mainboard, and now it’s failing to connect to the PC properly. Wondering whether one of the components in the new kit is bad, and causing the issues, though I have disconnected everything but the USB client DP module, and I’m still getting USB errors when connecting either Spider mainboard.
But the older mainboard, which had been running my IR heli controller, is definitely still working…I hooked it back up to the controller, and it’s still working fine. Just won’t connect via USB.
Turns out it was a PEBCAK in my case. I had connected my USB Client DP module to Z instead of DI. Thankfully, I didn’t release any magic smoke, and once connected properly the board is visible via USB. Man, do I feel stupid. :-[
RTFMs big brother, it stands for Problem Exists Between Chair and Keyboard. A popular term among office network engineers and IT support departments, it arose due to a need to descretly describe [edit] nice smelling [/edit] users (who falsely believe the system or computer is at fault) in thier presence with a suitably technical and legitimate-sounding term.[/quote]
