- Not without additional electronics.
- Shift it right and use that value as a 7bit address.
Unfortunately, those chips come with pre-configured slave addresses and cannot be changed :wall:
Look at the Devantech LCD picture : it shows address 0xC6, which is greater than 0x7F. As Architect stated, you should then use (0xC6 >> 1) as base address for your I2C device in this case.
First of all thanks for the help!
:dance: Woohoo. :dance:
Some tweaking still needed, but so far so good. I think I need to add some pull down resistors to the board. There are other options I want to play with - for example I wish the value would be closer to 0 when pulled low (is 240 now).
In the video, it’s showing a 10bit value of 1 one of the ADC channels.
- (1009) Initially it’s connected to 5v, which is how the board is powered with - via the Gadgeteer breakout.
- (496) Then I disconnect the power, and the value drops.
- (752) Next I connect it to the 3v3 pin.
- (240) Then I disconnect and plug into ground.
Below is the code, any suggestions would be appreciated (realizing this is just PoC code and hardly the finished product).
using GT = Gadgeteer;
namespace gMBN
public partial class Program
Font fnt;
I2CDevice MyI2C;
int address = 53;
fnt = Resources.GetFont(Resources.FontResources.NinaB);
I2CDevice.Configuration con = new I2CDevice.Configuration((byte)address, 400);
MyI2C = new I2CDevice(con);
setup();
GT.Timer t = new GT.Timer(1000);
t.Tick += (o) =>
t.Stop();
read();
t.Start();
t.Start();
void setup()
// start config
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[1];
// 1101 0110 -- Table on 14 // 0xD6 or 214
// 1 = Setup
// 101 = Internal Ref / An Input / Ref not connected / Internal ref always on -- Table 6 on page 19
// 0 = internal clock
// 1 = Unipolar
// 1 = No reset
// 0 = "don't care bit"
byte[] RegisterNum = new byte[1] { 0xD6 };
xActions[0] = I2CDevice.CreateWriteTransaction(RegisterNum);
if (MyI2C.Execute(xActions, 1000) == 0)
Debug.Print("Failed to perform I2C transaction");
Debug.Print("Success: ");
void read()
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[3];
// reading ADC 4
// 0110 1001 -- page 15 -- 105 or 0x69
// 0 = reading, aka confi
// 1 1 = *Converts channel selected by CS3-CS0. - table 5 on page 18
// 0 1 0 0 == selection of ADC4
// 1 == Single ended reading
byte[] RegisterNum = new byte[1] { 105 };
// to specify which channel
// value comes back in 2 bytes - datasheet page 16:
// The result is transmitted in two bytes; first four bits of
// the first byte are high, then MSB through LSB are consecutively
// clocked out.
byte[] RegisterValue1 = new byte[1];
xActions[1] = I2CDevice.CreateReadTransaction(RegisterValue1);
byte[] RegisterValue2 = new byte[1];
xActions[2] = I2CDevice.CreateReadTransaction(RegisterValue2);
// trim first 4 bits, and convert to 10bit value
var z = (RegisterValue1[0] & 15) << 8;
z+=RegisterValue2[0];
Debug.Print("Register value1 : " + RegisterValue1[0].ToString());
Debug.Print("Register value2 : " + RegisterValue2[0].ToString());
Debug.Print("10 bits: " + z);
displayN18.SimpleGraphics.Clear();
displayN18.SimpleGraphics.DisplayText(z.ToString(), fnt, GT.Color.White, 10, 10);
