I think i know what he means, this happen when you debug, its on a breakpoint, you then stop and press debug again - then it sometimes cannot attach debugger, you just reset then
I have written the following code as per tutorials Data Buses USB Client for a keyboard but I donât know why the instantiation
var kb = new Keyboard(usbclientController, usbClientSetting);
gives error that I should pass two parameters in the function Keyboard (unit id byte InterfaceIndex)
do you have any idea or example program for usb keyboard ?
What exactly are the error message(s) you are seeing?
the error says that I have to pass an id and interfaceindex in the function Keyboard not usbclientController and usbClientSetting
Please show all of your initialization code.
class Program
static void Main()
var usbClientSetting = new UsbClientSetting()
ManufactureName = âtttttttâ,
ProductName = âYYY2â,
VendorId = 0x1F26,
ProductId = 0x12,
SerialNumber = â01â,
var usbclientController = UsbClientController.GetDefault();
var key = new Key[] { Key.G, Key.H, Key.I, Key.Space, Key.E, Key.L, Key.E, Key.C, Key.T, Key.R, Key.O, Key.N, Key.I, Key.C, Key.S };
kb.Enable();
while (kb.DeviceState != DeviceState.Configured)
Thread.Sleep(100);// wait or use events
kb.Press(Key.LeftShift);// hold shift down
for (var i = 0; i < key.Length; i++)
kb.Stroke(key[i]);
Thread.Sleep(500);// type it twice a second
kb.Release(Key.LeftShift)
var usbHostController = UsbHostController.GetDefault();
usbHostController.OnConnectionChangedEvent += UsbHostController_OnConnectionChangedEvent;
usbHostController.Enable();
Are you trying to build a key capture device?
I am not comfortable providing assistance. I am out.
I tried to follow but I am confused. What have you gotten to work so far? Do you have a blinking LED working? Can you load and debug the blink LED?
Maybe we should do it step by step
What firmware version are you using? Look like too old version.
I have copied the program for a keyboard as UsbCleint but when I am in debugging mode I get an error
âSystem.NotSupportedExceptionâ in this function Acquire()
public UsbClientControllerApiWrapper(NativeApi api)
this.Api = api;
this.impl = api.Implementation;
this.Acquire();
this.dataReceivedDispatcher = NativeEventDispatcher.GetDispatcher("GHIElectronics.TinyCLR.NativeEventNames.UsbClient.DataReceived");
this.dataReceivedDispatcher.OnInterrupt += (apiName, d0, d1, d2, d3, ts) => { if (this.Api.Name == apiName) this.dataReceivedCallbacks?.Invoke(null, (uint)d0); };
this.deviceStateChangedDispatcher = NativeEventDispatcher.GetDispatcher("GHIElectronics.TinyCLR.NativeEventNames.UsbClient.DeviceStateChanged");
this.deviceStateChangedDispatcher.OnInterrupt += (apiName, d0, d1, d2, d3, ts) => { if (this.Api.Name == apiName) this.deviceStateChangedCallbacks?.Invoke(null, (DeviceState)d0); };
Did you switch to serial debugging to free up USB?
no but how to do that switch from DebugInterface to Serial. do you have a lien where the info about it ?
The info you need is right on the USB tutorial page
I followed the instructions on the USB-Tutorial but it is not sufficient
It works for us. Please provide more info.
It did not work but I have known the problem that I use a USB for debugging, and the same for the USB client that was the problem
That is exactly what I have been saying and what the tutorial clearly states.
