Hi. After being sick for many months, I’m getting back to my project, but I’m having trouble. I updated the firmware on my EMX project and the FEZ config reports the following:
HalSystemInfo.halVersion :4.2.0.0
HalSystemInfo.halVendorInfo :Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.clrVersion :4.2.0.0
ClrInfo.clrVendorInfo :Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion :4.2.0.0
SolutionReleaseInfo.solutionVersion: 4.2.11.0
SolutionReleaseInfo.solutionVendorInfo: Copyright © GHI Electronics, LLC
SoftwareVersion.BuildDate: Aug 15 2013
SoftwareVersion.CompilerVersion: 410713
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
My project compiles fine, but I get an error on deployment. I’ve tried deploying with NETMF versions 4.1, 4.2, and 4.3, but I get the same error no matter what version:
Found debugger!
Create TS.
Loading start at a0e00000, end a0e1383c
Assembly: mscorlib (4.2.0.0)
Assembly: Microsoft.SPOT.Native (4.2.0.0)
Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0)
Assembly: System.Security (4.2.0.0)
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.11.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
- ERROR!!! Firmware version does not match managed code version!!! *
- Invalid native checksum: Microsoft.SPOT.Hardware 0x7765AC69!=0xBF718024 *
Assembly: Microsoft.SPOT.Touch (4.2.0.0)
- Invalid native checksum: Microsoft.SPOT.Touch 0x4940D53E!=0x2D4E2DCC *
Resolving.
Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Assembly: System.Security (4.2.0.0) needs assembly ‘Microsoft.SPOT.Security.PKCS11’ (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Assembly: GHI.Premium.IO (4.2.11.0) needs assembly ‘GHI.Premium.System’ (4.2.11.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Error: a3000000
Waiting for debug commands…
The program ‘[3] Micro Framework application: Managed’ has exited with code 0 (0x0).
Any ideas what I need to do to resolve this issue? I did some searching on the forums and the solution always marked answer was to upgrade the firmware on the EMX. I’ve already done that … it upgraded to 4.2.11
Thank you.
