App deploying fine but issue with debugger. I don’t have this issue with FEZ Cobra III and G120TH
This is what I have in output window:
Looking for a device on transport ‘USB’
Found device port ‘USB’ with ID ‘e5482d3f-b502-48c2-9be8-31ece2666613’ for transport ‘Usb’
Starting device deployment…
Attempting to connect to device ‘USB:G400’ Iteration 0
Opening port \?\usb#vid_1b9f&pid_0102#0000000001#{d32d1d64-963d-463e-874a-8ec8c8082cbf}
Attaching debugger engine…
… debugger engine attached!
Querying device assemblies…
Found Assembly mscorlib 4.3.1.0
Adding pe file C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\gadgeteer.pe to deployment bundle
Attempting deployment…
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 407744 bytes
Assemblies successfully deployed to device.
Restarting interpreter…
Attaching to device…
Waiting for device to initialize…
The debugging target and the debugger engine failed to initialize because of unspecified device errors.
The debugger engine thread has terminated unexpectedly with error ‘Could not reconnect to the debugging target after rebooting it.’.
EDIT:
Installed VS2013 and reinstalled framework problem went away. Still strange why it worked for Cobra III and G120TH modules
