I bough this servo controller from pololu.
just checking in this awesome community if someone has already written code for this with gadgeteer.
@ MJ1984 - I used one of their other similar ones awhile back, probably have some code on the office puter I could dig up if no one else posts before then.
Thanks a lot Justin. I really appreciate the help.
I will have a squizz in the morning.
Righto - see if the below works, i haven’t tried it so not even sure if it will work as i cant seem to find my servo controller in my highly organised filing system
using Gadgeteer.Interfaces;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
private static GT.Interfaces.Serial _serialPort;
private GT.Timer _timer;
private const int MinAngle = 0;
private const int MaxAngle = 255;
private void ProgramStarted()
_serialPort = new GT.Interfaces.Serial(GT.Socket.GetSocket(8, true, null, null), 9600, Serial.SerialParity.None, Serial.SerialStopBits.One, 8, Serial.HardwareFlowControl.NotRequired, null);
_serialPort.Open();
_timer = new GT.Timer(2000);
_timer.Tick += new GT.Timer.TickEventHandler(TimerTick);
_timer.Start();
private void TimerTick(GT.Timer timer)
_timer.Stop();
for (int i = 50; i < 200; i++)
MoveServo(_serialPort, 1, i);
Thread.Sleep(100);
public static void MoveServo(GT.Interfaces.Serial comPort, int servoNumber, int servoPos)
if (servoPos < MinAngle || servoPos > MaxAngle)
return;
_serialPort.Write(new byte[] { 0xFF, Convert.ToByte(servoNumber.ToString()), Convert.ToByte(servoPos.ToString()) }, 0, 3);
Thanks Justin I will try this and let you know how it goes.
