GT.Timer declaration in Program.Started() method
Hi all,
is it save to declare a Gadgeteer GT.Timer in the Program.Started() method.
In the Gadgeteer Forum Nic Villar posted
http://www.netmf.com/gadgeteer/forum/default.aspx?g=posts&t=2347
Timers are declared outside of the ProgramStarted() method, and need at least one parameter: an interval, which is the time period between ticks. The interval can be specified in milliseconds by passing an integer as a parameter, or a TimeSpan object. A second optional parameter specifes the behaviour of the timer.
Is the timer action influenced by the GC if the GT.Timer is declared in the Program.Started() method.
Thanks, Roland
I have run the following in the emulator, and got an answer to the question. I would assume it would be the same on a real device.
While it works with Gadgeteer, which does all sorts of things under the covers, with standard NETMF timers I suspect it would not work.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GTimerTest
    public partial class Program
        private GT.Timer gcTimer = new GT.Timer(5000);
            GT.Timer tickTimer = new GT.Timer(1000);
            tickTimer.Tick += tickTimer_Tick;
            gcTimer.Tick += gcTimer_Tick;
            tickTimer.Start();
            gcTimer.Start();
        void gcTimer_Tick(GT.Timer timer)
            Debug.GC(true);
            Debug.Print("GC");
        void tickTimer_Tick(GT.Timer timer)
            Debug.Print("Tick");
@ Mike -
Thank you Mike, yes, it seems to work.
I just tried on a Cerbuino Bee
namespace GadgeteerApp2
        byte[] myByteArray;
            GT.Timer timer = new GT.Timer(500); // every 500ms
                timer.Tick +=timer_Tick;
                timer.Start();
            Debug.Print(timer.Interval.ToString());
            myByteArray = new byte[20000];
            Debug.GC(true);
runs with no problems.
For how long? Forever? Everything I know about C# and .NET says that the timer should eventually be garbage collected. However, your
won't because the timer is in use, specifically, waiting for
```cs]void timer_Tick(GT.Timer timer)[/code
to return.
I would always declare it class scope, because in .NET full-sized, I've seen timers GC'd once out of scope.  .NETMF may be different, but I would consider it bad practice to do it otherwise, because it's not guaranteed to not change, and declaring it in a method that will always be run buys you nothing.
@ Gregg - Gadgeteer does funny things… it might be keeping a reference to the timer internally. the answer requires a code review of the framework.
