I’m having some trouble with understanding exactly how to correctly return values from native functions. I’ve been trying to port a method that I’ve been using in .netmf just as a learning process really (of both the RLPlite process and the C language!), and to see if it’s much faster etc.
It works, and returns the value expected the first time it is called, but then each time after it returns a value that is growing! ???
This is the native code (takes a byte array of a floating point number and returns the float);
int RLP_charArrayToDouble(void *par0, int *par1, unsigned char *par2)
float *num = par0;
unsigned char *str = par2;
unsigned int length = par1[0];
bool decimalFound = false;
bool preDec = true;
float preDecimalMulti = (float)1;
float postDecimalMulti = 0.1;
float buffer;
float ret;
int i = 0;
for(i=0; i<length; i++)
if (str[i] == 0x2e)
decimalFound = true;
else if (str[i] != 0x2e)
if (decimalFound)
buffer = (float)(str[i] - '0');
ret = ret + (buffer * postDecimalMulti);
postDecimalMulti = postDecimalMulti / (float)10;
else if (!decimalFound)
ret = (ret * preDecimalMulti) + buffer;
if (preDec)
preDecimalMulti = (float)10;
preDec = false;
num[0] = ret;
return ret;
and the managed code that calls it (that hopefully explains what it does);
int ret = 0;
byte[] charArrayBytes = new byte[7];
charArrayBytes = Encoding.UTF8.GetBytes("143.617");
int[] length = new int[1];
length[0] = charArrayBytes.Length;
float[] floatReturned = new float[1];
floatReturned[0] = 0;
ret = RLP_ReturnFloatTest.Invoke(floatReturned, length, charArrayBytes);
Debug.Print("'143.617' returned as:" + floatReturned[0].ToString());
The first time I get 143.617 but then 14505.3164, 1450675.12, 145067648, 2147483647! I also have to completely re-program tinybooter and the firmware to reset this! ??? This morning I ran it a few times and it returned the correct value everytime, which in itself is also odd.
I’m a bit stuck now. Should I be disposing of variables or something, or managing them in a different way?
I wondered also if there is an accuracy issue as this always returns 143.617004;
int RLP_ReturnFloatTest(void *par0, int *par1, unsigned char *par2)
float *num = par0;
num[0] = 143.617000;
return 0;
Is that a separate issue that is related to the accuracy of the processor?
This is the output from FEZconfig (Cerbuino Bee);
[quote]Loader (TinyBooter) version information:
4.2.6.1 on this computer.
4.2.6.1 on this device.
The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
4.2.6.2 on this computer.
4.2.6.2 on this device.
The Firmware (TinyCLR) is up to date. <<<[/quote]
Any help is much appreciated. I’m fairly new to all languages and self taught so please be kind!
