I tried one of those, didn’t like it at all. Maybe they have fixed them, otherwise, the software was really buggy. I had to return mine because it was basically unusable.
EDIT: The one I tried was it’s serial brother, yeah, don’t get the SERIAL one.
But I dont use their commands atall I create a bitmap in memory (just like FEZ do)
And use the fast autowrite command (I think its 0xB0) to flush the screen. I belive you can just do this with the KS0108B
There are many c routines on the web for this controller. Also I was looking at a parallel port class on the web for hooking several IO pins into a parallel port so you can use it with a parallel LCD
[url]http://informatix.miloush.net/Microframework/Examples.aspx[/url]
Unfortunately i have a bunch of 128x64 displays here. It’s not something that needs to be updated fast so hopefully i can dump out the data fast enough for a refresh rate of 1-2 fps.
I’m 22 pins from using every pin on the Panda with this project
Most PC power supplies have a largish minimum load requirement, like 10% or more of rated load, below which they will not regulate properly. Years ago I took an old 200W PC supply and used a few 5W power resistors as a dummy load and a few banana jacks as power taps.
I’m using old Antec NeoPower psu’s, they are great for hacking. I’m using one with just the blue wire tied to ground (power on) already, but it’s only 600W (3x15A 12v rails) but i want more and i want current limiting so i can have a high amp, yet current limited 12v supply so i’m going to convert a spare 800w that i repaired previously
The antec’s are very solidly built with good quality parts, not like the $20 psu’s heh. I’ll post it’s progress on my blog and here once i get the pandas
